跳转到主内容
Nikon D90 LCD Replacement
你所需要的
  1. Nikon D90 LCD Replacement, Rear Case: 步骤 1 中的图像 1,2 Nikon D90 LCD Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Slide the eyepiece up and off the viewfinder.
  2. Nikon D90 LCD Replacement: 步骤 2 中的图像 1,1
    • Using a PH000 screwdriver, remove the two 4.8mm Phillips screws from the back of the viewfinder.
    • Some screws may be JIS. Be wary of this if your PH000 does not feel like it is properly gripping the screws.
  3. Nikon D90 LCD Replacement: 步骤 3 中的图像 1,1
    • Remove the two 6.4mm Phillips screws on the right side of the camera, near the SD card slot.
  4. Nikon D90 LCD Replacement: 步骤 4 中的图像 1,1
    • Remove the two 6.4mm Phillips screws on the left side of the camera, near the I/O ports.
  5. Nikon D90 LCD Replacement: 步骤 5 中的图像 1,1
    • On the bottom of the camera,
    • remove the two 5.3mm Phillips screws
    • and the other two 6.3mm Phillips screws.
  6. Nikon D90 LCD Replacement: 步骤 6 中的图像 1,3 Nikon D90 LCD Replacement: 步骤 6 中的图像 2,3 Nikon D90 LCD Replacement: 步骤 6 中的图像 3,3
    • Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step.
  7. Nikon D90 LCD Replacement: 步骤 7 中的图像 1,2 Nikon D90 LCD Replacement: 步骤 7 中的图像 2,2
    • Lift the rear case off of the back of the camera.
    • Don't pull the casing completely off yet, as the ribbon cables are still connected.
    • Be mindful of the two clips, making sure to keep the bottom panel far enough away to clear them.
  8. Nikon D90 LCD Replacement: 步骤 8 中的图像 1,1
    • Set the rear casing off to the side so you can access the ZIF connectors.
    • The orientation shown in the picture seems to be the best position for the casing to sit comfortably without stressing the ribbon cable connections.
  9. Nikon D90 LCD Replacement: 步骤 9 中的图像 1,3 Nikon D90 LCD Replacement: 步骤 9 中的图像 2,3 Nikon D90 LCD Replacement: 步骤 9 中的图像 3,3
    • Use a spudger to lift the black tab on the ZIF connector.
    • Disconnect the ribbon cables from their respective ZIF connectors on the logic board.
  10. Nikon D90 LCD Replacement: 步骤 10 中的图像 1,1
    • Separate the rear casing from the camera.
  11. Nikon D90 LCD Replacement, LCD: 步骤 11 中的图像 1,1
    • Peel back the yellow tape covering the cable connector on the back of the casing you removed.
  12. Nikon D90 LCD Replacement: 步骤 12 中的图像 1,3 Nikon D90 LCD Replacement: 步骤 12 中的图像 2,3 Nikon D90 LCD Replacement: 步骤 12 中的图像 3,3
    • Using the spudger, rock the connector back and forth to disconnect the cable.
  13. Nikon D90 LCD Replacement: 步骤 13 中的图像 1,2 Nikon D90 LCD Replacement: 步骤 13 中的图像 2,2
    • Remove the eight Phillips screws securing the brackets to the rear casing.
    • Four 4.2mm screws securing the large metal bracket.
    • Four 3.4mm screws securing the bracket that covers the ribbon cable.
  14. Nikon D90 LCD Replacement: 步骤 14 中的图像 1,2 Nikon D90 LCD Replacement: 步骤 14 中的图像 2,2
    • Remove the silver metal plate.
  15. Nikon D90 LCD Replacement: 步骤 15 中的图像 1,2 Nikon D90 LCD Replacement: 步骤 15 中的图像 2,2
    • Fold the ribbon cables up and out of the way.
    • Remove the metal shield covering the LCD.
  16. Nikon D90 LCD Replacement: 步骤 16 中的图像 1,2 Nikon D90 LCD Replacement: 步骤 16 中的图像 2,2
    • Lift and remove the LCD from the rear case.
结论
18等其他人完成本指南。
Ryan Lutz
于09/27/11注册
3,011 声望
创作了3篇指南
4条评论
Awesome Guide. Thanks!
boarderx - 回复
really marvelous.
I am thankful for this totorial which help me to recover my D90
ch4 - 回复
So much easier than any modern smatphones. Just be careful not to mix up different screws. Thanks for the guide.
Cristi - 回复
Be extra careful removing / installing those ribbon flex cables. I think I damaged mine, so the screen and the buttons on the back cover no longer work and I may need to buy new parts. In order to disconnect the cables from ZIF connectors in Step 9, the tiny black bar (flap) on the connector needs to be pushed towards the camera bottom, and the cables will come off by themselves. When installing the cables back, make sure the black bar is up, align the cables against the connector and close the black bar back, locking the cables.
Ivan Vidyakin - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 52
总计 10,268
