跳转到主内容
加入维修社区 - 创建账户
Nikon D80 Rear LCD Screen Replacement
你所需要的
    1. Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: 步骤 1 中的图像 1,3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: 步骤 1 中的图像 2,3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: 步骤 1 中的图像 3,3
      • Using a Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover.
      询问修复机器人
      添加评论
    2. Nikon D80 Rear LCD Screen Replacement: 步骤 2 中的图像 1,3 Nikon D80 Rear LCD Screen Replacement: 步骤 2 中的图像 2,3 Nikon D80 Rear LCD Screen Replacement: 步骤 2 中的图像 3,3
      在这个步骤中使用的工具:
      • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
      • Pull the orange connector cable away from the main body of the camera using the tweezers.
      • Remove the back cover.
      询问修复机器人
      添加评论
    3. Nikon D80 Rear LCD Screen Replacement: 步骤 3 中的图像 1,2 Nikon D80 Rear LCD Screen Replacement: 步骤 3 中的图像 2,2
      • Using a Philips #00 screwdriver, remove the three 4.3 mm screws by rotating screwdriver to the left.
      • Use the Phillips #00 screwdriver to remove the two 3.4 mm screws.
      询问修复机器人
      添加评论
    4. Nikon D80 Rear LCD Screen Replacement: 步骤 4 中的图像 1,2 Nikon D80 Rear LCD Screen Replacement: 步骤 4 中的图像 2,2
      • Using blunt tweezers, gently flip the small locking flap of the zero force insertion connector up for both connectors.
      • Use blunt tweezers to pull the left ribbon connector out of the zero insertion force connector.
      • Using the same tweezers, pull the right ribbon connector out of the zero insertion force connector.
      询问修复机器人
      添加评论
    5. Nikon D80 Rear LCD Screen Replacement: 步骤 5 中的图像 1,2 Nikon D80 Rear LCD Screen Replacement: 步骤 5 中的图像 2,2
      • Slide out the LCD screen by pulling towards the right.
      • Remove the LCD screen.
      • The buttons beside the screen fall out easily. Remember where they were and put them back when finished with the screen.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Sara Martin
于10/09/17注册
610 声望
创作了4篇指南
团队
USF Tampa, Team S1-G1, Leahy Fall 2017 USF Tampa, Team S1-G1, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G1
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 53
总计 4,123
