跳转到主内容
加入维修社区 - 创建账户
Nikon COOLPIX S9500 Navigation Panel Replacement
你所需要的
    1. Nikon COOLPIX S9500 Navigation Panel Replacement, Removing Screws: 步骤 1 中的图像 1,1
      • Remove the three 4 mm screws from the bottom of the camera using a #00 Phillips screwdriver.
      • Remove the single 3.5 mm screw from the bottom of the camera using a #00 Phillips screwdriver.
      询问修复机器人
      添加评论
    2. Nikon COOLPIX S9500 Navigation Panel Replacement: 步骤 2 中的图像 1,2 Nikon COOLPIX S9500 Navigation Panel Replacement: 步骤 2 中的图像 2,2
      • With the bottom of the camera facing you, slide the latch on the compartment to the left.
      • Swing the battery compartment door open.
      • Remove the 3.5 mm screw from the inside with a #00 Phillips screwdriver.
      询问修复机器人
      添加评论
    3. Nikon COOLPIX S9500 Navigation Panel Replacement: 步骤 3 中的图像 1,1
      • With the screen facing you, locate the two 3.5 mm screws on the left face of the camera. Remove them using a #00 Phillips screwdriver.
      询问修复机器人
      添加评论
    4. Nikon COOLPIX S9500 Navigation Panel Replacement: 步骤 4 中的图像 1,1
      • With the screen facing you, locate the three 3.5 mm screws on the right face of the camera. Remove them with a #00 Phillips screwdriver.
      • Two of the screws are located under the port tabs.
      询问修复机器人
      添加评论
    5. Nikon COOLPIX S9500 Navigation Panel Replacement: 步骤 5 中的图像 1,2 Nikon COOLPIX S9500 Navigation Panel Replacement: 步骤 5 中的图像 2,2
      • Locate the crease where the case comes together.
      • Using a plastic prying tool, pry at the line to remove the camera case.
      • It may take several attempts to remove the case. Remember to pry at all the crease locations on the camera, and not just one spot.
      询问修复机器人
      添加评论
    1. Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel Removal: 步骤 6 中的图像 1,3 Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel Removal: 步骤 6 中的图像 2,3 Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel Removal: 步骤 6 中的图像 3,3
      • Slide the yellow navigation panel to the right so that it can be lifted up.
      • It may take a little pressure to get the panel to separate.
      • Be careful not to damage the ribbon cable that is still attached to the camera.
      询问修复机器人
      添加评论
    2. Nikon COOLPIX S9500 Navigation Panel Replacement: 步骤 7 中的图像 1,1
      • Remove the three 4 mm screws with a #00 Phillips screwdriver.
      询问修复机器人
      添加评论
    3. Nikon COOLPIX S9500 Navigation Panel Replacement: 步骤 8 中的图像 1,1
      • Locate the magnet and copper tape on the left side of the camera.
      • Gently pull the copper tape off of the metal plate.
      • The copper tape is attached with some glue, so a little force will be needed to detach it.
      询问修复机器人
      添加评论
    4. Nikon COOLPIX S9500 Navigation Panel Replacement: 步骤 9 中的图像 1,3 Nikon COOLPIX S9500 Navigation Panel Replacement: 步骤 9 中的图像 2,3 Nikon COOLPIX S9500 Navigation Panel Replacement: 步骤 9 中的图像 3,3
      • Lift the screen up and swing it to the right, exposing the circuit board underneath.
      • The navigation panel should still be attached to the circuit board with a ribbon cable as indicated in red.
      • Detach the ribbon cable that is connecting the LCD screen and the circuit board.
      添加评论
    1. Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel: 步骤 10 中的图像 1,1
      • Detach the ribbon cable connecting the navigation panel to the camera.
      • The navigation panel can now be removed.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jim Bui
于01/20/15注册
829 声望
创作了6篇指南
团队
USF Tampa, Team 1-4, Blackwell Winter 2015 USF Tampa, Team 1-4, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G4
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 26
总计 1,430
