跳转到主内容
Nexus 6P Back Cover Replacement
你所需要的
  1. Nexus 6P Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 Nexus 6P Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 Nexus 6P Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    • It is possible to remove the back cover with an iOpener as seen in this guide but it's a lengthy and difficult procedure. We recommend a heat gun or something similar. The adhesive in the Nexus 6P is extremely sticky and especially the glass and plastic cover on the backside break or bend most of the time whilst doing this repair.
    • Use a SIM card eject tool, to pop out and remove the SIM card tray.
    • Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
  2. Nexus 6P Back Cover Replacement: 步骤 2 中的图像 1,3 Nexus 6P Back Cover Replacement: 步骤 2 中的图像 2,3 Nexus 6P Back Cover Replacement: 步骤 2 中的图像 3,3
    • The knife is really sharp. Take care, not to cut yourself or your phone.
    • Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
    • Slide the opening pick underneath the plastic cover to cut the adhesive.
  3. Nexus 6P Back Cover Replacement: 步骤 3 中的图像 1,2 Nexus 6P Back Cover Replacement: 步骤 3 中的图像 2,2
    • Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
    • Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
  4. Nexus 6P Back Cover Replacement: 步骤 4 中的图像 1,3 Nexus 6P Back Cover Replacement: 步骤 4 中的图像 2,3 Nexus 6P Back Cover Replacement: 步骤 4 中的图像 3,3
    • Glass may break. Wear protective glasses and protective gloves.
    • Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
    • Pry off the glass cover.
  5. Nexus 6P Back Cover Replacement: 步骤 5 中的图像 1,3 Nexus 6P Back Cover Replacement: 步骤 5 中的图像 2,3 Nexus 6P Back Cover Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the six Phillips #00 screws.
    • Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
  6. Nexus 6P Back Cover Replacement: 步骤 6 中的图像 1,3 Nexus 6P Back Cover Replacement: 步骤 6 中的图像 2,3 Nexus 6P Back Cover Replacement: 步骤 6 中的图像 3,3
    • Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
    • The knife is really sharp, be careful, not to cut yourself or your phone.
    • Insert a second opening pick and slide it to the top left corner.
    • Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
    • Remove the rear cover.
结论
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
11等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
247,178 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,735篇指南
1指南评论
The first picture of Step-6 is very misleading when looking at guitar pick.
By mistake, I pulled apart my front glass from digitizer by taking the pic as reference.
Vijay Bhaskar - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 74
总计 4,386
