简介
参照本指南对Nexus 6P智能手机中的电池进行更换。 在重新装配时需要使用新的粘合剂。
如果你的手机电池已经出现鼓胀,请参考 take appropriate precautions.
你所需要的
重新组装手机时,请按照相反的步骤进行,并在已经有粘合剂的地方涂上新的粘合剂。
138等其他人完成本指南。
由衷感谢以下译者:
88%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
37条评论
In case anyone is wondering, I was able to get the two small back covers to reassemble without using new adhesive. I didn’t have any on hand so I just used a heat gun to warm the adhesive that was left over and firmly held them in place. So far it seems to be holding well.
Adhesive? I’m wondering what kind of adhesive to use for reassembly?
Didn’t need any additional adhesive and the iopener worked fine for both loosening adhesive for disassembly and getting it sticky again for reassembly.. Managed not to break the glass camera cover!
any tips on using the iOpener for the top glass? It dosen’t seem to be helping me at all. :(
These were great instructions, but have to admit this was quite a hair-raising process because of the amount of heat that was required to soften the adhesive and the amount of force needed to pry things apart. Luckily, I have a digital hot air source (Sparkfun 303D) used for surface mount electronics. The safe temperature ended up being about 200 F. If I did it again would be much easier because I know the glass piece at the top is not as fragile as I thought. So, heat gun, definitely. iOpener would be next to useless, especially to loosen under battery. But be careful not to concentrate the heat and melt plastic or make glass crack. Adhesive under battery definitely reusable, easy to peel off old battery. Go slow with the whole process and it will be successful!
