跳转到主内容
Nexus 5X Screen Assembly Replacement
你所需要的
  1. Nexus 5X Screen Assembly Replacement, SIM Card Tray: 步骤 1 中的图像 1,3 Nexus 5X Screen Assembly Replacement, SIM Card Tray: 步骤 1 中的图像 2,3 Nexus 5X Screen Assembly Replacement, SIM Card Tray: 步骤 1 中的图像 3,3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Screen Assembly Replacement, Rear Panel: 步骤 2 中的图像 1,3 Nexus 5X Screen Assembly Replacement, Rear Panel: 步骤 2 中的图像 2,3 Nexus 5X Screen Assembly Replacement, Rear Panel: 步骤 2 中的图像 3,3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  3. Nexus 5X Screen Assembly Replacement: 步骤 3 中的图像 1,3 Nexus 5X Screen Assembly Replacement: 步骤 3 中的图像 2,3 Nexus 5X Screen Assembly Replacement: 步骤 3 中的图像 3,3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Screen Assembly Replacement: 步骤 4 中的图像 1,2 Nexus 5X Screen Assembly Replacement: 步骤 4 中的图像 2,2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
  5. Nexus 5X Screen Assembly Replacement, Midframe: 步骤 5 中的图像 1,1
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
  6. Nexus 5X Screen Assembly Replacement: 步骤 6 中的图像 1,2 Nexus 5X Screen Assembly Replacement: 步骤 6 中的图像 2,2
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
  7. Nexus 5X Screen Assembly Replacement: 步骤 7 中的图像 1,2 Nexus 5X Screen Assembly Replacement: 步骤 7 中的图像 2,2
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
  8. Nexus 5X Screen Assembly Replacement: 步骤 8 中的图像 1,2 Nexus 5X Screen Assembly Replacement: 步骤 8 中的图像 2,2
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
  9. Nexus 5X Screen Assembly Replacement: 步骤 9 中的图像 1,2 Nexus 5X Screen Assembly Replacement: 步骤 9 中的图像 2,2
    • Make sure all the clips are free.
    • Carefully remove the midframe.
  10. Nexus 5X Screen Assembly Replacement, Battery Disconnect: 步骤 10 中的图像 1,2 Nexus 5X Screen Assembly Replacement, Battery Disconnect: 步骤 10 中的图像 2,2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
  11. Nexus 5X Screen Assembly Replacement, Battery: 步骤 11 中的图像 1,1
    • Use an iOpener to loosen the adhesive beneath the battery. Apply the iOpener on the back of the phone for at least two minutes.
  12. Nexus 5X Screen Assembly Replacement: 步骤 12 中的图像 1,2 Nexus 5X Screen Assembly Replacement: 步骤 12 中的图像 2,2
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert the flat end of a spudger under the bottom left corner of the battery and gently pry upwards.
    • The adhesive is only located beneath the edges of the battery so there's no need to pry beneath its center.
    • If you are having trouble prying up the battery, the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
  13. Nexus 5X Screen Assembly Replacement: 步骤 13 中的图像 1,2 Nexus 5X Screen Assembly Replacement: 步骤 13 中的图像 2,2
    • Insert the flat end of a spudger under the bottom right corner of the battery and gently pry upwards to loosen the remaining adhesive.
  14. Nexus 5X Screen Assembly Replacement: 步骤 14 中的图像 1,1
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Before installing a new battery remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place for 5-10 seconds.
  15. 注意:步骤 15-18 源自标记为进行中的 指南
    Nexus 5X Screen Assembly Replacement, Motherboard Assembly: 步骤 15 中的图像 1,1
    • Use an iOpener to loosen the adhesive beneath the rear facing camera. Place the iOpener across the top part of the phone for about 30 seconds.
  16. Nexus 5X Screen Assembly Replacement: 步骤 16 中的图像 1,2 Nexus 5X Screen Assembly Replacement: 步骤 16 中的图像 2,2
    • Apply the flat end of a spudger to the left side of the rear facing camera and carefully lever it up. Make sure all of the adhesive underneath is loosened.
  17. Nexus 5X Screen Assembly Replacement: 步骤 17 中的图像 1,2 Nexus 5X Screen Assembly Replacement: 步骤 17 中的图像 2,2
    • Use the flat end of a spudger to pry up the display flex connector.
  18. Nexus 5X Screen Assembly Replacement: 步骤 18 中的图像 1,3 Nexus 5X Screen Assembly Replacement: 步骤 18 中的图像 2,3 Nexus 5X Screen Assembly Replacement: 步骤 18 中的图像 3,3
    • Grip the lower part of the motherboard with your fingers and carefully lift it upwards.
    • There's a small plastic clip next to the rear-facing camera that holds the motherboard in place.
    • Gently pull the motherboard towards the bottom edge to free it from the plastic clip next to the rear-facing camera.
    • Carefully lift the motherboard out of the frame.
    • Be careful—the two cameras are still connected to the board.
  19. Nexus 5X Screen Assembly Replacement, Screen Assembly: 步骤 19 中的图像 1,2 Nexus 5X Screen Assembly Replacement, Screen Assembly: 步骤 19 中的图像 2,2
    在这个步骤中使用的工具:
    • The power and volume buttons are held in position with small rubber feet sitting on small plastic elevations.
    • Use a pair of tweezers to free the rubber feet and lift the power button upwards.
    • Remove the power button.
  20. Nexus 5X Screen Assembly Replacement: 步骤 20 中的图像 1,2 Nexus 5X Screen Assembly Replacement: 步骤 20 中的图像 2,2
    • Free the rubber feet of the volume button with a pair of tweezers and lift it upwards.
    • Remove the volume button.
    • You can find spare button parts here if your buttons are damaged, or if you want to exchange them for cosmetic reasons.
  21. Nexus 5X Screen Assembly Replacement: 步骤 21 中的图像 1,3 Nexus 5X Screen Assembly Replacement: 步骤 21 中的图像 2,3 Nexus 5X Screen Assembly Replacement: 步骤 21 中的图像 3,3
    • Use a pair of tweezers to gently peel of the tape that holds down the earpiece speaker.
    • Use the tweezers to carefully lift the earpiece speaker out of its gasket.
    • In case you're having trouble removing the earpiece speaker you can use an iOpener to loosen the adhesive beneath.
    • Remove the earpiece speaker.
    • Note the earpiece speaker orientation. Be sure to reinstall it the same direction.
  22. Nexus 5X Screen Assembly Replacement: 步骤 22 中的图像 1,3 Nexus 5X Screen Assembly Replacement: 步骤 22 中的图像 2,3 Nexus 5X Screen Assembly Replacement: 步骤 22 中的图像 3,3
    • The adhesive underneath the vibration motor is strong. Use an iOpener on the top part of the screen for about 30 seconds to loosen it.
    • Use a pair of tweezers to pry up and remove the vibration motor.
  23. Nexus 5X Screen Assembly Replacement: 步骤 23 中的图像 1,3 Nexus 5X Screen Assembly Replacement: 步骤 23 中的图像 2,3 Nexus 5X Screen Assembly Replacement: 步骤 23 中的图像 3,3
    • Insert the pointy end of a spudger into the opening of the headphone jack.
    • Use the spudger to lever the headphone jack up and out of its gasket by pulling it upwards.
    • In case you're having trouble removing the headphone jack, you can apply a heated iOpener on the bottom front for about 30 seconds to loosen the adhesive underneath.
    • Remove the headphone jack.
  24. Nexus 5X Screen Assembly Replacement: 步骤 24 中的图像 1,2 Nexus 5X Screen Assembly Replacement: 步骤 24 中的图像 2,2
    • Use a pair of tweezers to gently peel off the RGB LED notification indicator.
    • Remove the RGB LED notification indicator.
  25. Nexus 5X Screen Assembly Replacement: 步骤 25 中的图像 1,1
    • Check your replacement part for any other components that need to be transferred before reassembly.
结论
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
Dominik Schnabelrauch
于11/23/16注册
247,693 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,788篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 1,707
