跳转到主内容
加入维修社区 - 创建账户
Nexus 4 Battery Replacement
你所需要的
    1. Nexus 4 Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 Nexus 4 Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
      在这个步骤中使用的工具:
      SIM Card Eject Tool
      $2.99
      • Power off the phone, by long-pressing the power button and touching Power off.
      • Remove the SIM tray using the SIM Card Eject Tool.
      • This step is required in order to remove the back case.
      询问修复机器人
      添加评论
    2. Nexus 4 Battery Replacement: 步骤 2 中的图像 1,1
      在这个步骤中使用的工具:
      T5 Torx Screwdriver
      $5.49
      添加评论
    3. Nexus 4 Battery Replacement: 步骤 3 中的图像 1,3 Nexus 4 Battery Replacement: 步骤 3 中的图像 2,3 Nexus 4 Battery Replacement: 步骤 3 中的图像 3,3
      • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
      • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
      添加评论
    1. Nexus 4 Battery Replacement, Battery: 步骤 4 中的图像 1,2 Nexus 4 Battery Replacement, Battery: 步骤 4 中的图像 2,2
      • Remove the two 1.8 mm Phillips screws holding down the battery connector.
      • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
      添加评论
    2. Nexus 4 Battery Replacement, Battery removal: 步骤 5 中的图像 1,2 Nexus 4 Battery Replacement, Battery removal: 步骤 5 中的图像 2,2
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • Remove the blue tape that secures the white antenna cable to the battery.
      • Using a spudger, carefully disconnect the white antenna cable.
      • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
      • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
      • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Start by seating the top of the back to the phone, then gently snap the back in place working from the top to the bottom.
取消:我没有完成这个指南。
153等其他人完成本指南。
Kaitlyn Jones
于01/27/13注册
4,964 声望
创作了8篇指南
团队
Cal Poly, Team 3-32, Amido Winter 2013 Cal Poly, Team 3-32, Amido Winter 2013 的会员
CPSU-AMIDO-W13S3G32
4 名成员
创作了64篇指南
14指南评论
I have made some arrangement to clarify particularly using pictures from the teardown that are just perfect. The original picture was not detailed and did not show the battery in place.
Gaetan - 回复 分享
If you can't power on after battery replace:
Charge for an hour
Try holding down power plus volume down while plugging in power
If that doesn't work replug inside battery connector (this fixed for me)
Recommend data backup before in case you can't get it booting.
Chris Harrow - 回复 分享
Just did this - thanks for all the instructions, easy if you have the right tools
raymondw999 - 回复 分享
followed these instructions and the device boots up OK but then immediately shuts down. getting into recovery mode and checking the logs I can see that the phone thinks the battery is over temperature (790C vs max of 68C). Hopefully it's just a poor connection where I fitted it. I'll take it apart and try again later.
keith.griffiths - 回复 分享
Note that it is very easy to break a screw holding the battery connector - don't over tighten. I've managed to hold down the end of the connector, towards the center of the phone, with a washer fitted to a nearby screw. It's been working fine for 6 months
Rodney - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 59
总计 116,685
