跳转到主内容
加入维修社区 - 创建账户
Nextbook NXA8QC116B Front Camera Replacement
你所需要的
    1. Nextbook NXA8QC116B Front Camera Replacement, Battery: 步骤 1 中的图像 1,3 Nextbook NXA8QC116B Front Camera Replacement, Battery: 步骤 1 中的图像 2,3 Nextbook NXA8QC116B Front Camera Replacement, Battery: 步骤 1 中的图像 3,3
      • If you see any leakage coming from the tablet do not open the back cover!
      • Ensure you do not pry around the buttons. This could result in damage and render them inoperable.
      • •With the tip of the thin metal spudger in place, use a prying motion to work the spudger down the side to the corner of the device.
      询问修复机器人
      添加评论
    2. Nextbook NXA8QC116B Front Camera Replacement: 步骤 2 中的图像 1,2 Nextbook NXA8QC116B Front Camera Replacement: 步骤 2 中的图像 2,2
      • Continue working the spudger downward and pry with the spudger until the bottom left-hand corner of the tablet is reached.
      询问修复机器人
      添加评论
    3. Nextbook NXA8QC116B Front Camera Replacement: 步骤 3 中的图像 1,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 3 中的图像 2,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 3 中的图像 3,3
      • Along the bottom of the tablet, keep using a working and prying motion with the spudger to loosen the cover.
      询问修复机器人
      添加评论
    4. Nextbook NXA8QC116B Front Camera Replacement: 步骤 4 中的图像 1,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 4 中的图像 2,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 4 中的图像 3,3
      • Continue prying motion until the bottom right-hand corner of the tablet is reached.
      询问修复机器人
      添加评论
    5. Nextbook NXA8QC116B Front Camera Replacement: 步骤 5 中的图像 1,2 Nextbook NXA8QC116B Front Camera Replacement: 步骤 5 中的图像 2,2
      • Work the spudger to the upper left-hand corner of the tablet.
      询问修复机器人
      添加评论
    6. Nextbook NXA8QC116B Front Camera Replacement: 步骤 6 中的图像 1,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 6 中的图像 2,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 6 中的图像 3,3
      • Be careful once you get to the top of the tablet with the spudger so as not to damage the headphone jack and other ports.
      • When prying along the top of the tablet, try to keep the spudger between 70 to 85 degrees (almost perpendicular) to the tablet screen.
      • Continue working the spudger around the tablet until the cover of the device comes off
      询问修复机器人
      添加评论
    7. Nextbook NXA8QC116B Front Camera Replacement: 步骤 7 中的图像 1,2 Nextbook NXA8QC116B Front Camera Replacement: 步骤 7 中的图像 2,2
      • Separate from the cover from the tablet.
      询问修复机器人
      添加评论
    8. Nextbook NXA8QC116B Front Camera Replacement: 步骤 8 中的图像 1,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 8 中的图像 2,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 8 中的图像 3,3
      • Locate and carefully remove the yellow cellophane tape from the red and black speaker wires that connect the speaker to the edge of the motherboard.
      询问修复机器人
      添加评论
    9. Nextbook NXA8QC116B Front Camera Replacement: 步骤 9 中的图像 1,2 Nextbook NXA8QC116B Front Camera Replacement: 步骤 9 中的图像 2,2
      在这个步骤中使用的工具:
      • Locate and carefully remove the yellow cellophane tape with tweezers from the battery connector and black and red speaker wires on the edge of the motherboard.
      询问修复机器人
      添加评论
    10. Nextbook NXA8QC116B Front Camera Replacement: 步骤 10 中的图像 1,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 10 中的图像 2,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 10 中的图像 3,3
      • Using small pliers, carefully disconnect the male battery connector from the motherboard.
      • If you are only replacing the front camera, skip to step 17 in the camera replacement guide and continue.
      询问修复机器人
      添加评论
    11. Nextbook NXA8QC116B Front Camera Replacement: 步骤 11 中的图像 1,1
      • If the battery is leaking or bulging, stop and get away from it!
      • Carefully remove the gray square pad glued to both the white ribbon cable and the battery by pulling slowly.
      询问修复机器人
      添加评论
    12. Nextbook NXA8QC116B Front Camera Replacement: 步骤 12 中的图像 1,1
      • Locate the white ribbon cable Zero Insertion Force (ZIF) connector between the battery and the motherboard, and peel the yellow cellophane tape off the connector.
      询问修复机器人
      添加评论
    13. Nextbook NXA8QC116B Front Camera Replacement: 步骤 13 中的图像 1,2 Nextbook NXA8QC116B Front Camera Replacement: 步骤 13 中的图像 2,2
      • Flip up the gray retainer clip on the white ribbon cable ZIF connector on the motherboard with your fingernail. If you do not have fingernails long enough, carefully use a black plastic spudger.
      询问修复机器人
      添加评论
    14. Nextbook NXA8QC116B Front Camera Replacement: 步骤 14 中的图像 1,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 14 中的图像 2,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 14 中的图像 3,3
      • Remove the white ribbon cable and carefully peel it off the battery.
      询问修复机器人
      添加评论
    15. Nextbook NXA8QC116B Front Camera Replacement: 步骤 15 中的图像 1,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 15 中的图像 2,3 Nextbook NXA8QC116B Front Camera Replacement: 步骤 15 中的图像 3,3
      • Move the spudger in a left-to-right scraping motion to loosen the glue until the battery is separated from the tablet.
      询问修复机器人
      添加评论
    16. Nextbook NXA8QC116B Front Camera Replacement: 步骤 16 中的图像 1,1
      • Remove the battery.
      添加评论
    1. Nextbook NXA8QC116B Front Camera Replacement, Front Camera: 步骤 17 中的图像 1,1
      • Locate the front camera on the upper left-hand corner
      询问修复机器人
      添加评论
    2. Nextbook NXA8QC116B Front Camera Replacement: 步骤 18 中的图像 1,2 Nextbook NXA8QC116B Front Camera Replacement: 步骤 18 中的图像 2,2
      在这个步骤中使用的工具:
      • Remove the yellow cellophane tape with the tweezers from the ZIF connector.
      询问修复机器人
      添加评论
    3. Nextbook NXA8QC116B Front Camera Replacement: 步骤 19 中的图像 1,2 Nextbook NXA8QC116B Front Camera Replacement: 步骤 19 中的图像 2,2
      • Using your fingernail, flip up the ZIF connector retainer. If you do not have fingernails long enough, use the black plastic spudger.
      询问修复机器人
      添加评论
    4. Nextbook NXA8QC116B Front Camera Replacement: 步骤 20 中的图像 1,2 Nextbook NXA8QC116B Front Camera Replacement: 步骤 20 中的图像 2,2
      • Be careful when removing the camera. The underside of the camera head has adhesive and may be adhered to the tablet. If this happens, use the black plastic spudger to carefully pry up on the underside of the camera head to loosen it from the tablet before pulling on the ribbon cable with the tweezers.
      • Use tweezers to remove the front camera by pulling.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 29
总计 590
