跳转到主内容
加入维修社区 - 创建账户
Nextbook 8 Speaker Replacement
你所需要的
    1. Nextbook 8 Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Nextbook 8 Speaker Replacement, Battery: 步骤 1 中的图像 2,2
      • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
      • Slide the tool along the edge to work the back cover off.
      • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
      添加评论
    2. Nextbook 8 Speaker Replacement: 步骤 2 中的图像 1,2 Nextbook 8 Speaker Replacement: 步骤 2 中的图像 2,2
      • Remove the tape covering the motherboard.
      • Remove the silver tape holding the white ribbon cables to the battery.
      询问修复机器人
      添加评论
    3. Nextbook 8 Speaker Replacement: 步骤 3 中的图像 1,2 Nextbook 8 Speaker Replacement: 步骤 3 中的图像 2,2
      • Use a spudger to carefully disconnect the battery connector from the motherboard.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      添加评论
    4. Nextbook 8 Speaker Replacement: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
      • Pull the ribbon cables out of the connectors with tweezers or two fingers.
      询问修复机器人
      添加评论
    5. Nextbook 8 Speaker Replacement: 步骤 5 中的图像 1,2 Nextbook 8 Speaker Replacement: 步骤 5 中的图像 2,2
      • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
      • The battery is very malleable, so do not try to pull it off all at once.
      添加评论
    1. Nextbook 8 Speaker Replacement, Speaker: 步骤 6 中的图像 1,1
      • Use a small Phillips screwdriver to remove the 0.116 inch screw holding the red and black wires in place on the inside of the back cover.
      询问修复机器人
      添加评论
    2. Nextbook 8 Speaker Replacement: 步骤 7 中的图像 1,1
      • Remove the two 0.116 inch screws holding the speaker assembly in place.
      询问修复机器人
      添加评论
    3. Nextbook 8 Speaker Replacement: 步骤 8 中的图像 1,1
      • Carefully pry the speaker off of the back cover with a spudger.
      • Note: There is glue holding the speaker to the back cover, so it will take some work to get it off.
      询问修复机器人
      添加评论
    4. Nextbook 8 Speaker Replacement: 步骤 9 中的图像 1,1
      • Use a desoldering tool to remove the solder holding the red and black speaker wires to the motherboard.
      • If you do not have a desoldering tool, you can use a solder gun to remove the old solder.
      • Caution: Soldering guns get extremely hot.
      询问修复机器人
      添加评论
    5. Nextbook 8 Speaker Replacement: 步骤 10 中的图像 1,1
      • Use the soldering gun to solder the new speaker wires to the motherboard where the original wires were connected.
      • Make sure that you connect the red wire to the positive terminal on the right, and the black wire to the negative terminal on the left.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Dylan Wiese
于03/11/15注册
1,889 声望
创作了5篇指南
团队
Colorado Springs, Team 5-1, Panko Spring 2015 Colorado Springs, Team 5-1, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G1
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 24
总计 1,644
