此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
特色学生指南
该指南是我们优秀学生的辛勤劳动的成果,iFixit的工作人员认为这个很酷。
简介
转到步骤 1 ↓本指南将逐步介绍如何拆卸 Netgear Arlo 中的镜头组件 PCB 板。开始本指南前,请先取出电池。
你所需要的
工具
要重新组装设备,请按相反顺序执行这些说明。
8指南评论
hi I took out the battery befor it was finished downloading new firmware, now there is no connection, no blue light. Can you help or is the camer garbage?
Rune Koppang - 回复 分享
I struggled a bit with the ribbon cable connections, they need to be lifted up from the side the cable enters. They are sort of hinged like a door but lying on its side. Once it is stood up vertically, the cable will pull out. For the longer one I found it was important to lift as much of it up at once otherwise it will break if you lift one end and not the other. Once the cable is reinserted, they can just be pushed back down, same as before, supporting the full length when you do. If one comes off it is possible to push it back onto the hinge but it is very very tricky and took a while.
