跳转到主内容
加入维修社区 - 创建账户
Netgear Arlo 2 Camera HD Security System Camera/Lens Replacement
你所需要的
  1. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Case: 步骤 1 中的图像 1,3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Case: 步骤 1 中的图像 2,3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Case: 步骤 1 中的图像 3,3
    • Unscrew the two 3.0 mm Phillips #00 screws on the bottom of the camera.
    • Open the battery compartment on the bottom by pushing the switch marked in orange to the side and pushing the bottom of the camera back, sliding it open.
    询问修复机器人
    添加评论
  2. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 2 中的图像 1,2 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 2 中的图像 2,2
    • Remove the bottom piece of the case over the battery compartment by placing a plastic opening tool underneath the edge of the case and prying it up.
    • Unscrew the four 3.0 mm Phillips #00 screws on the outside of the battery pocket.
    询问修复机器人
    添加评论
  3. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 3 中的图像 1,2 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 3 中的图像 2,2
    • When facing the camera lens, the left panel of the case will be removed first (more steps are needed for the right panel).
    • Place the plastic opening tool between the two pieces of the case and pry them apart from the bottom.
    • Gently pull the side of the case off as it comes loose.
    询问修复机器人
    添加评论
  4. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 4 中的图像 1,2 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 4 中的图像 2,2
    • Unscrew the smaller 3.0 mm Phillips #00 screw in the center on the back of the device.
    • Flip the camera over and unscrew the center 3.0 mm Phillips #00 screw above the SYNC button.
    询问修复机器人
    添加评论
  5. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 5 中的图像 1,2 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, gently pry the right panel from the device.
    • Replace either side of the plastic case as needed.
    询问修复机器人
    添加评论
  6. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Camera/Lens: 步骤 6 中的图像 1,3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Camera/Lens: 步骤 6 中的图像 2,3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement, Camera/Lens: 步骤 6 中的图像 3,3
    • Unscrew the four 4.0 mm Phillips #00 screws on either side of the transparent case.
    • Separate the transparent half of the case from the white half.
    • Only separate the two halves enough for them to be apart. The flat ribbon cable is short and its connection is delicate.
    询问修复机器人
    添加评论
  7. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 7 中的图像 1,2 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 7 中的图像 2,2
    • Lift the small thin black rectangular latch that covers the connectors of the flat ribbon cable.
    • The latch is very flat, so use a finger nail or a spudger to lift it. Do not use any sharp edge like a knife as it will likely damage the device!
    • With the latch lifted, the cable will pull away freely as you separate the white half from the transparent half.
    询问修复机器人
    添加评论
  8. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 8 中的图像 1,3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 8 中的图像 2,3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 8 中的图像 3,3
    • Repeat the same process as in Step 6 to release the flat ribbon cable from the black rectangular latch
    • Unscrew the six black 3.0 mm Phillips #00 screws that hold the black motherboard on.
    • Release the clip at the bottom left corner of the black motherboard by pinching the wings at either side of the clip.
    • Be sure that the transparent case or the black motherboard are being held or resting on a surface so that neither falls when the clip is released.
    询问修复机器人
    添加评论
  9. Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 9 中的图像 1,3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 9 中的图像 2,3 Netgear Arlo 2 Camera HD Security System Camera/Lens  Replacement: 步骤 9 中的图像 3,3
    • Remove the black plastic that contains the camera from its place.
    • Discard and replace this part as needed.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Ben Ingleson
于10/30/18注册
109 声望
撰写一个指南
团队
UMass Dartmouth, Team S2-G4, Peak Fall 2018 UMass Dartmouth, Team S2-G4, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G4
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 30
总计 1,952
