跳转到主内容
Nest x Yale Lock Motherboard Replacement
你所需要的
  1. Nest x Yale Lock Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Before proceeding, make sure the batteries are removed to avoid being electrocuted and damage to the lock
    • If you do not know how to remove the batteries then I would recommend looking at our battery replacement guide for help.
  2. Nest x Yale Lock Motherboard Replacement: 步骤 2 中的图像 1,2 Nest x Yale Lock Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove 3 screws as shown to remove the first cover.
    • The 3 screws are 0.25 inches length
  3. Nest x Yale Lock Motherboard Replacement: 步骤 3 中的图像 1,1
    • Using a pin to push down the knot holding the wire and the tweezer to safely remove the wire from the motherboard
  4. Nest x Yale Lock Motherboard Replacement: 步骤 4 中的图像 1,2 Nest x Yale Lock Motherboard Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a spudger or plastic tool to lift the ZIF lock upward (as shown in the first picture).
    • Use tweezers to remove the ribbon cable from the motherboard.
  5. Nest x Yale Lock Motherboard Replacement: 步骤 5 中的图像 1,1
    • Continue to remove 2 screws holding the motherboard to the lock shell.
    • The screws are 0.20 inches in length.
  6. Nest x Yale Lock Motherboard Replacement: 步骤 6 中的图像 1,2 Nest x Yale Lock Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use an opening tool to push the motherboard out as shown in the picture.
结论
Bryant Duong
于09/26/22注册
379 声望
创作了2篇指南
团队
CSU Los Angeles, Team 5-3, Adachi Fall 2022 CSU Los Angeles, Team 5-3, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S5G3
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 20
总计 811
