跳转到主内容
Nest x Yale Lock Battery Replacement
你所需要的
  1. Nest x Yale Lock Battery Replacement, Battery: 步骤 1 中的图像 1,2 Nest x Yale Lock Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure to insert a thin-metal pin into the hole on top and press it down until you feel the cover is loose and then take it out.
  2. Nest x Yale Lock Battery Replacement: 步骤 2 中的图像 1,1
    • Once you take out the cover pry the batteries out, then replace them and ensure that the batteries are aligned correctly.
  3. Nest x Yale Lock Battery Replacement: 步骤 3 中的图像 1,1
    • Once the batteries are put in correctly, you can put the cover back on and it should be working.
结论
Bryant Duong
于09/26/22注册
379 声望
创作了2篇指南
团队
CSU Los Angeles, Team 5-3, Adachi Fall 2022 CSU Los Angeles, Team 5-3, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S5G3
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 49
过去 30 天: 227
总计 2,591
