跳转到主内容
加入维修社区 - 创建账户
Nest x Yale Lock Deadbolt Button Replacement
你所需要的
    1. Nest x Yale Lock Deadbolt Button Replacement, Motherboard: 步骤 1 中的图像 1,1
      • Before proceeding, make sure the batteries are removed to avoid being electrocuted and damage to the lock
      • If you do not know how to remove the batteries then I would recommend looking at our battery replacement guide for help.
      添加评论
    2. Nest x Yale Lock Deadbolt Button Replacement: 步骤 2 中的图像 1,2 Nest x Yale Lock Deadbolt Button Replacement: 步骤 2 中的图像 2,2
      • Remove 3 screws as shown to remove the first cover.
      • The 3 screws are 0.25 inches length
      添加评论
    3. Nest x Yale Lock Deadbolt Button Replacement: 步骤 3 中的图像 1,1
      • Using a pin to push down the knot holding the wire and the tweezer to safely remove the wire from the motherboard
      添加评论
    4. Nest x Yale Lock Deadbolt Button Replacement: 步骤 4 中的图像 1,2 Nest x Yale Lock Deadbolt Button Replacement: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      • Use a spudger or plastic tool to lift the ZIF lock upward (as shown in the first picture).
      • Use tweezers to remove the ribbon cable from the motherboard.
      添加评论
    5. Nest x Yale Lock Deadbolt Button Replacement: 步骤 5 中的图像 1,1
      • Continue to remove 2 screws holding the motherboard to the lock shell.
      • The screws are 0.20 inches in length.
      添加评论
    6. Nest x Yale Lock Deadbolt Button Replacement: 步骤 6 中的图像 1,2 Nest x Yale Lock Deadbolt Button Replacement: 步骤 6 中的图像 2,2
      • Use an opening tool to push the motherboard out as shown in the picture.
      询问修复机器人
      添加评论
    1. Nest x Yale Lock Deadbolt Button Replacement, Deadbolt Button: 步骤 7 中的图像 1,2 Nest x Yale Lock Deadbolt Button Replacement, Deadbolt Button: 步骤 7 中的图像 2,2
      • After, fully removing the motherboard.
      • Remove the .25 in screws circled in red to remove the lock compartment.
      • Lastly, take out the lock as shown in the second picture.
      询问修复机器人
      添加评论
    2. Nest x Yale Lock Deadbolt Button Replacement: 步骤 8 中的图像 1,1
      • Move onto removing the .25 inches screws in red to take out the battery holder.
      • Remove the .15 inches screws in orange as well.
      询问修复机器人
      添加评论
    3. Nest x Yale Lock Deadbolt Button Replacement: 步骤 9 中的图像 1,2 Nest x Yale Lock Deadbolt Button Replacement: 步骤 9 中的图像 2,2
      • After unscrewing the battery holder you can now see the lights circled in red
      • The part squared in orange is a rubber that reflects the light of the LED.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
CSU Los Angeles, Team 5-3, Adachi Fall 2022 CSU Los Angeles, Team 5-3, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S5G3
5 名成员
创作了60篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 36
总计 1,010
