跳转到主内容
加入维修社区 - 创建账户
Nerf Vortex Vigilon Trigger Replacement
你所需要的
    1. Nerf Vortex Vigilon Trigger Replacement, Removing the slide screws: 步骤 1 中的图像 1,1
      • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
      • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
      • Both sides of the slide will come off when the screws are removed.
      询问修复机器人
      添加评论
    2. Nerf Vortex Vigilon Trigger Replacement, Removing the slide pieces: 步骤 2 中的图像 1,1
      • Lift both slide pieces off of the gun.
      询问修复机器人
      添加评论
    1. Nerf Vortex Vigilon Trigger Replacement, Removing the outer screws: 步骤 3 中的图像 1,2 Nerf Vortex Vigilon Trigger Replacement, Removing the outer screws: 步骤 3 中的图像 2,2
      • Remove the twelve #00 1 cm Phillips screws.
      • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
      • Rotate the gun so that the front is facing you to remove the final screw.
      询问修复机器人
      添加评论
    2. Nerf Vortex Vigilon Trigger Replacement, Removing the outside cover: 步骤 4 中的图像 1,1
      • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
      • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
      • The magazine will slide down automatically as you remove the cover.
      询问修复机器人
      添加评论
    1. Nerf Vortex Vigilon Trigger Replacement, Removing the inner mechanism's screws: 步骤 5 中的图像 1,1
      • Remove the seven #00 1 cm Phillips screws that attach the inner mechanism to the back cover.
      • Remove the #00 1.2 cm Phillips screw located to the right of the white casing.
      询问修复机器人
      添加评论
    2. Nerf Vortex Vigilon Trigger Replacement, Removing the front cover: 步骤 6 中的图像 1,3 Nerf Vortex Vigilon Trigger Replacement, Removing the front cover: 步骤 6 中的图像 2,3 Nerf Vortex Vigilon Trigger Replacement, Removing the front cover: 步骤 6 中的图像 3,3
      • An orange block will likely fall out as you remove the front cover. The clip and spring will fall out as well, if they have not already.
      • Wiggle the front cover out from under the white piece and lift up from the gun.
      • Pulling the cover off is tricky due to its inner fitting.
      • Be sure to replace the orange block, spring, and clip before this step in reassembly.
      询问修复机器人
      添加评论
    3. Nerf Vortex Vigilon Trigger Replacement, Removing the inner mechanism: 步骤 7 中的图像 1,1
      • The spring, cap, and rotating lever will likely fall out as you remove the inner mechanism.
      • Disconnect the inner mechanism from the outer cover by lifting the inner mechanism towards you.
      • Be sure to replace the spring, cap, and rotating lever before this step in reassembly.
      询问修复机器人
      添加评论
    1. Nerf Vortex Vigilon Trigger Replacement, Removing the trigger screws: 步骤 8 中的图像 1,1
      • Flip over the inner mechanism.
      • Remove the two #00 1 cm Phillips screws that hold the trigger in place.
      询问修复机器人
      添加评论
    2. Nerf Vortex Vigilon Trigger Replacement, Removing the trigger: 步骤 9 中的图像 1,2 Nerf Vortex Vigilon Trigger Replacement, Removing the trigger: 步骤 9 中的图像 2,2
      • Slightly lift the area of the trigger that had the screw towards you, and rotate the trigger counter-clockwise.
      • Lifting the trigger is somewhat tricky.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Cara Pew
于09/29/14注册
932 声望
创作了7篇指南
团队
Cal Poly, Team 13-6, Forte Fall 2014 Cal Poly, Team 13-6, Forte Fall 2014 的会员
CPSU-FORTE-F14S13G6
5 名成员
创作了42篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 45
总计 4,074
