简介
You will only need a screwdriver to take apart this Nerf gun and access the loading spring. Also obtain a new spring if needed.
你所需要的
Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
Remove the twelve #00 1 cm Phillips screws.
Rotate the gun so that the front is facing you to remove the final screw.
Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
另外一个人完成了本指南。
