简介
The plunger works with the main spring to launch the dart. The o-ring creates a tight seal to stop air from leaking out when the main spring is compressed. This allows for a more powerful shot.
你所需要的
Pull slide back.
Pull backwards on release buttons and slide magazine out.
Push slide back forward and pull trigger.
Use the Phillips #0 Screwdriver to remove these 9 screws.
All screws marked in red are 9.6 mm Phillips #0 screws.
Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
Pull slide back to reveal more screws.
Remove these 2 screws.
Push slide forward.
Pull trigger to release compression of the main spring.
Screws are 9.6 mm Phillips #0.
Remove the screws on the plunger cap.
Tug the plunger cap off.
Pull the remaining half of the plunger out the back of the gun.
2等其他人完成本指南。
