简介
You will learn how to remove and replace the wires connecting the batteries to the LED. This guide does involve soldering so please take the time to learn how to solder or bring it to someone who knows how to.
你所需要的
Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
Gently pull up on the circuit board located near the gun handle until it separates from the gun.
Pinch the clips holding the circuit board to the laser assembly and remove the circuit board.
另外一个人完成了本指南。
