跳转到主内容
加入维修社区 - 创建账户
Nerf N-Strike Elite Strongarm Unloading Button Replacement
你所需要的
    1. Nerf N-Strike Elite Strongarm Unloading Button Replacement, Outer Shell: 步骤 1 中的图像 1,2 Nerf N-Strike Elite Strongarm Unloading Button Replacement, Outer Shell: 步骤 1 中的图像 2,2
      • Lay the Nerf Strongarm on its side, left side facing up.
      询问修复机器人
      添加评论
    2. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 2 中的图像 1,2 Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 2 中的图像 2,2
      • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
      询问修复机器人
      添加评论
    3. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 3 中的图像 1,1
      • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
      • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
      询问修复机器人
      添加评论
    4. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 4 中的图像 1,1
      • At this time, remove the blaster cover to reveal its internals.
      • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
      询问修复机器人
      添加评论
    5. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 5 中的图像 1,1
      • Once the screws have been removed, lift the top half of the gun off.
      • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
      • Take care and try not to lose any smaller pieces as you open it up.
      • Locking tab for attachments.
      添加评论
    1. Nerf N-Strike Elite Strongarm Unloading Button Replacement, Unloading Button: 步骤 6 中的图像 1,3 Nerf N-Strike Elite Strongarm Unloading Button Replacement, Unloading Button: 步骤 6 中的图像 2,3 Nerf N-Strike Elite Strongarm Unloading Button Replacement, Unloading Button: 步骤 6 中的图像 3,3
      • Look inside the top cover of the blaster and locate the tab extending from the unloading button. It shouldn't be too hard to find as pictured since it will be the only orange piece.
      • Inspect the button's location for signs of debris impeding its operation. Replace if necessary.
      • Ensure the unloading button has a 45 degree angle contact surface.
      询问修复机器人
      添加评论
    2. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 7 中的图像 1,2 Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 7 中的图像 2,2
      • To make the relevant pieces accessible, remove the barrel from its position on the bottom half of the blaster cover.
      询问修复机器人
      添加评论
    3. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 8 中的图像 1,2 Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 8 中的图像 2,2
      • On the bottom half of the blaster, ensure the tab from the button makes contact with the barrel assembly.
      • Clear out any debris in the way, or replace the button as necessary.
      询问修复机器人
      添加评论
    4. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 9 中的图像 1,3 Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 9 中的图像 2,3 Nerf N-Strike Elite Strongarm Unloading Button Replacement: 步骤 9 中的图像 3,3
      • Reassemble and test the unloading button's functionality. The button should correctly lock and release the blaster's dart barrel!
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
USF Tampa, Team 5-4, Blackwell Fall 2015 USF Tampa, Team 5-4, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S5G4
4 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 48
总计 10,151
