跳转到主内容
加入维修社区 - 创建账户
Nerf N-Strike Elite Retaliator Trigger Spring Replacement
你所需要的
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Case Disassembly: 步骤 1 中的图像 1,1
      • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
      询问修复机器人
      添加评论
    2. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 步骤 2 中的图像 1,1
      • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
      询问修复机器人
      添加评论
    3. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 步骤 3 中的图像 1,1
      • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
      添加评论
    4. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 步骤 4 中的图像 1,2 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 步骤 4 中的图像 2,2
      • Remove the stock attachment point by removing the two 8mm Phillips head screws.
      询问修复机器人
      添加评论
    5. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 步骤 5 中的图像 1,2 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 步骤 5 中的图像 2,2
      • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
      • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
      • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
      添加评论
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: 步骤 6 中的图像 1,3 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: 步骤 6 中的图像 2,3 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: 步骤 6 中的图像 3,3
      • Carefully pull the orange trigger upward and backward to remove it from the blaster.
      • This component is under spring pressure. Wear appropriate personal protective equipment to shield your eyes.
      • Remove the spring from the rear of the trigger.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
ericharman
于03/02/16注册
1,440 声望
创作了5篇指南
1指南评论
ok, taken the spring out. now what?
Kelvin Mead - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 36
总计 10,148
