跳转到主内容
加入维修社区 - 创建账户
Nabi Jr Battery Replacement
你所需要的
    1. Nabi Jr Battery Replacement, Rear Case: 步骤 1 中的图像 1,1
      • Remove the red rubber case from the device. This should come off with ease.
      询问修复机器人
      添加评论
    2. Nabi Jr Battery Replacement: 步骤 2 中的图像 1,1
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
      询问修复机器人
      添加评论
    3. Nabi Jr Battery Replacement: 步骤 3 中的图像 1,1
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
      询问修复机器人
      添加评论
    4. Nabi Jr Battery Replacement: 步骤 4 中的图像 1,1
      • After loosening the back cover, remove it from the device so you can get at the innards.
      询问修复机器人
      添加评论
    1. Nabi Jr Battery Replacement, Battery: 步骤 5 中的图像 1,1
      • Lift the battery up from the motherboard.
      • Don't rip the soldered wires from the board.
      • The battery is stuck to the motherboard with adhesive, it may take a little pull to separate.
      询问修复机器人
      添加评论
    2. Nabi Jr Battery Replacement: 步骤 6 中的图像 1,1
      • Remove the battery from the motherboard
      • De-solder the colored wires
      • Be sure to note the order in which the wires are connected to the board before desoldering them.
      • Be careful while removing the solder off of the colored battery wires. The soldering iron will be extremely hot
      询问修复机器人
      添加评论
    3. Nabi Jr Battery Replacement: 步骤 7 中的图像 1,2 Nabi Jr Battery Replacement: 步骤 7 中的图像 2,2
      • Replace the old battery with the new one
      • Solder the wires of the new battery into the pads on the motherboard
      • Be careful when soldering the wires in. Soldering iron will be extremely hot
      询问修复机器人
      添加评论
    4. Nabi Jr Battery Replacement: 步骤 8 中的图像 1,1
      • Once the wires are fully soldered, put the new battery back to the initial position
      • Close the case by putting the back cover back on the device
      • Will take some force
      • Make sure the battery is not in the way of the back cover
      询问修复机器人
      添加评论
    5. Nabi Jr Battery Replacement: 步骤 9 中的图像 1,1
      • Once the back cover is on, screw in the four screws that you had taken off in the beginning
      • Put the red rubber casing back on.
      询问修复机器人
      添加评论
结论
If all the steps were followed correctly, the device should be fully closed and ready to go
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G3
3 名成员
创作了12篇指南
7指南评论
Thank you for sharing the idea ,but I need that NABI JR battery. So ,where from I can purchase it .
Lus Ka - 回复 分享
I have seen them on ebay but it's easier to find a Nabi 2 battery on ebay. The Nabi 2 battery is quite a bit larger but with a very minor mod to the Nabi Jr. the Nabi 2 battery will fit and give you a much longer run time from a single charge.
darcshadow - 回复 分享
My old Nabi jr battery is a plug in with 2 reds 1 white and 2 black wires. My new Cameron sino battery is blue green red yellow black. What is the order to resolder them.
Dennis Blixt - 回复 分享
I have the same problem with the problem of the replacement battery not having the same wiring configuration or plug. Did you ever get this resolved?
Delores Duke - 回复 分享
Where can I buy the battery live in Mexico
Roos - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 43
总计 12,364
