跳转到主内容
加入维修社区 - 创建账户
Nabi Big Tab HD24 Power Button Replacement
你所需要的
    1. Nabi Big Tab HD24 Power Button Replacement, Back Assembly: 步骤 1 中的图像 1,1
      • Ensure that the tablet is facing you with the screen on the table.
      • Locate the four red rubber stops at the corners.
      询问修复机器人
      添加评论
    2. Nabi Big Tab HD24 Power Button Replacement: 步骤 2 中的图像 1,1
      • Use your fingers to carefully peel them off the device to reveal the screws underneath.
      询问修复机器人
      添加评论
    3. Nabi Big Tab HD24 Power Button Replacement: 步骤 3 中的图像 1,1
      • Use a Phillips #1 screwdriver to remove the 9.5 mm screw in each of the four corners.
      询问修复机器人
      添加评论
    4. Nabi Big Tab HD24 Power Button Replacement: 步骤 4 中的图像 1,1
      • Flip the tablet over such that the screen is facing upwards.
      • Locate the the 4 small openings on the sides of the tablet.
      • There should be 2 on the bottom of the tablet, 1 on each side of the tablet viewing it from the front as if you were using it.
      • Do not confuse the openings with the charging port or the USB ports. The openings will be labelled with an icon of a small fan, the Nabi logo.
      询问修复机器人
      添加评论
    5. Nabi Big Tab HD24 Power Button Replacement: 步骤 5 中的图像 1,1
      • Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
      • Repeat for the other three openings.
      询问修复机器人
      添加评论
    6. Nabi Big Tab HD24 Power Button Replacement: 步骤 6 中的图像 1,2 Nabi Big Tab HD24 Power Button Replacement: 步骤 6 中的图像 2,2
      • Flip the device over so that the back assembly is facing you.
      • Use a plastic opening tool to carefully pry open the device from its hinges.
      • Take care when opening the device as there are cables running internally that are connected to both the front and the back assemblies.
      询问修复机器人
      添加评论
    7. Nabi Big Tab HD24 Power Button Replacement: 步骤 7 中的图像 1,2 Nabi Big Tab HD24 Power Button Replacement: 步骤 7 中的图像 2,2
      • Locate the white port that connects the back panel to the circuit board on the back of the display.
      • Carefully pull the plastic connector straight out.
      询问修复机器人
      添加评论
    8. Nabi Big Tab HD24 Power Button Replacement: 步骤 8 中的图像 1,1
      • Be careful of the aluminum foil tape, as it can easily rip.
      • Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
      • Do not try to pull the ribbon cables off the screen as there is a plastic piece surrounding the ribbon cables glued onto the metal display.
      询问修复机器人
      添加评论
    9. Nabi Big Tab HD24 Power Button Replacement: 步骤 9 中的图像 1,1
      • Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
      • Leave the connector disconnected but still intact with the metal display.
      询问修复机器人
      添加评论
    10. Nabi Big Tab HD24 Power Button Replacement: 步骤 10 中的图像 1,1
      • Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
      • Apply a downward force to carefully peel the grey plastic off of the metal display.
      询问修复机器人
      添加评论
    11. Nabi Big Tab HD24 Power Button Replacement: 步骤 11 中的图像 1,1
      • Locate the two cables running on both sides of the device found at the bottom side of the screen.
      询问修复机器人
      添加评论
    12. Nabi Big Tab HD24 Power Button Replacement: 步骤 12 中的图像 1,2 Nabi Big Tab HD24 Power Button Replacement: 步骤 12 中的图像 2,2
      • Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
      • Do not pull from the red and black cable as it is not very sturdy and may come undone from the connector.
      询问修复机器人
      添加评论
    1. Nabi Big Tab HD24 Power Button Replacement, Power Button: 步骤 13 中的图像 1,2 Nabi Big Tab HD24 Power Button Replacement, Power Button: 步骤 13 中的图像 2,2
      • Locate the power button assembly on the side with all the circuit boards.
      • The power button will be on the side closest to the screen when the device is opened up.
      询问修复机器人
      添加评论
    2. Nabi Big Tab HD24 Power Button Replacement: 步骤 14 中的图像 1,1
      • Lift up the black plastic tab holding the white fiber cable with the blue tip.
      询问修复机器人
      添加评论
    3. Nabi Big Tab HD24 Power Button Replacement: 步骤 15 中的图像 1,1
      • Remove the fiber cable with a blue tip by gently sliding it out.
      询问修复机器人
      添加评论
    4. Nabi Big Tab HD24 Power Button Replacement: 步骤 16 中的图像 1,2 Nabi Big Tab HD24 Power Button Replacement: 步骤 16 中的图像 2,2
      • Remove the 2 silver 4.5 mm screws holding the power button assembly in place using the Phillips #1 screwdriver.
      • Take out the circuit board and replace it with your new one.
      • Be sure not to remove the black padding along the edge of the tablet.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 4-1, Livingston Fall 2016 Cal Poly, Team 4-1, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G1
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 32
总计 881
