跳转到主内容
加入维修社区 - 创建账户
NP-R540-JA09US Keyboard Replacement
你所需要的
  1. NP-R540-JA09US Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
  2. NP-R540-JA09US Keyboard Replacement: 步骤 2 中的图像 1,1
    • Pull the two latches outward.
  3. NP-R540-JA09US Keyboard Replacement: 步骤 3 中的图像 1,2 NP-R540-JA09US Keyboard Replacement: 步骤 3 中的图像 2,2
    • Slide the battery out of the laptop.
  4. NP-R540-JA09US Keyboard Replacement, Optical Drive: 步骤 4 中的图像 1,1
    • Remove securing screw with the PH0 head.
  5. NP-R540-JA09US Keyboard Replacement: 步骤 5 中的图像 1,1
    • Slide the optical drive out and remove it from the device.
  6. NP-R540-JA09US Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,1
    • Remove the two Phillips #0 screws labeled KBD.
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
  7. NP-R540-JA09US Keyboard Replacement: 步骤 8 中的图像 1,1
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
  8. NP-R540-JA09US Keyboard Replacement: 步骤 9 中的图像 1,2 NP-R540-JA09US Keyboard Replacement: 步骤 9 中的图像 2,2
    • Disconnect the keyboard cable from the motherboard.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 39
总计 1,172
