跳转到主内容
加入维修社区 - 创建账户
Mpow MPBH063 Indicator Light Bulb Replacement
你所需要的
    1. Mpow MPBH063 Indicator Light Bulb Replacement, Battery: 步骤 1 中的图像 1,3 Mpow MPBH063 Indicator Light Bulb Replacement, Battery: 步骤 1 中的图像 2,3 Mpow MPBH063 Indicator Light Bulb Replacement, Battery: 步骤 1 中的图像 3,3
      • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
      • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
      询问修复机器人
      添加评论
    2. Mpow MPBH063 Indicator Light Bulb Replacement: 步骤 2 中的图像 1,1
      在这个步骤中使用的工具:
      • Remove four JIS J00 12mm screws.
      • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
      询问修复机器人
      添加评论
    3. Mpow MPBH063 Indicator Light Bulb Replacement: 步骤 3 中的图像 1,1
      • Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
      • Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
      • Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
      询问修复机器人
      添加评论
    4. Mpow MPBH063 Indicator Light Bulb Replacement: 步骤 4 中的图像 1,1
      • Hold down the small lever on the white, plastic plug attached to the battery wires, and detach the wires from the white, plastic plug outlet on the motherboard.
      询问修复机器人
      添加评论
    1. Mpow MPBH063 Indicator Light Bulb Replacement, Motherboard: 步骤 5 中的图像 1,1
      • Unplug all wires that are connected to the motherboard.
      询问修复机器人
      添加评论
    2. Mpow MPBH063 Indicator Light Bulb Replacement: 步骤 6 中的图像 1,2 Mpow MPBH063 Indicator Light Bulb Replacement: 步骤 6 中的图像 2,2
      在这个步骤中使用的工具:
      • Detach the motherboard from the speaker using the tech knife and the adhesive remover to remove the adhesive securing the motherboard.
      • Use iFixit Adhesive Remover as directed.
      • Use the precision tweezers with the blunt head to carefully grip and pull out the motherboard.
      • Proceed with caution when using the tech knife and removing the motherboard as you do not want to cause injury to yourself or the device.
      询问修复机器人
      添加评论
    1. Mpow MPBH063 Indicator Light Bulb Replacement, Indicator Light Bulb: 步骤 7 中的图像 1,1
      在这个步骤中使用的工具:
      • Use the adhesive remover to loosen the light bulb.
      • Gently remove bulb with the precision tweezers.
      • Insert new light bulb and secure into place by using an adhesive.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 572
