跳转到主内容
加入维修社区 - 创建账户
Motorola Xoom 2 Battery Replacement
你所需要的
    1. Motorola Xoom 2 Battery Replacement, Backplate: 步骤 1 中的图像 1,3 Motorola Xoom 2 Battery Replacement, Backplate: 步骤 1 中的图像 2,3 Motorola Xoom 2 Battery Replacement, Backplate: 步骤 1 中的图像 3,3
      • Pry off the silver top back cover (the panel around the camera) with iFixit opening picks or a similar implement.
      询问修复机器人
      添加评论
    2. Motorola Xoom 2 Battery Replacement: 步骤 2 中的图像 1,2 Motorola Xoom 2 Battery Replacement: 步骤 2 中的图像 2,2
      • Using a T5 screwdriver, unscrew the four 1.5mm screws holding the main back cover. These screws are arranged in a line across the top of the back of the device.
      询问修复机器人
      添加评论
    3. Motorola Xoom 2 Battery Replacement: 步骤 3 中的图像 1,3 Motorola Xoom 2 Battery Replacement: 步骤 3 中的图像 2,3 Motorola Xoom 2 Battery Replacement: 步骤 3 中的图像 3,3
      • Turn the device over and using a pry tool and the opening picks, gently apply pressure between the outside edge of the seal marked with the arrow. Slowly move around the edges of the device, applying even pressure, and separate the back plate from the display.
      • There is adhesive between the back-plate and battery.
      询问修复机器人
      添加评论
    4. Motorola Xoom 2 Battery Replacement: 步骤 4 中的图像 1,1
      • Remove the back plate from your device.
      询问修复机器人
      添加评论
    1. Motorola Xoom 2 Battery Replacement, Battery: 步骤 5 中的图像 1,2 Motorola Xoom 2 Battery Replacement, Battery: 步骤 5 中的图像 2,2
      • Using a Torx T5 screwdriver, remove the four 1.5mm screws holding down the battery around its perimeter.
      询问修复机器人
      添加评论
    2. Motorola Xoom 2 Battery Replacement: 步骤 6 中的图像 1,3 Motorola Xoom 2 Battery Replacement: 步骤 6 中的图像 2,3 Motorola Xoom 2 Battery Replacement: 步骤 6 中的图像 3,3
      • Using a Torx T5 screwdriver remove the two 1.5mm screws holding down the battery leads and carefully pry the battery leads loose from the cable clips with a spudger.
      • Following best safety practices, insulate the red positive lead by wrapping the connector with any form of non-conductive tape, such as masking tape or electrical tape.
      询问修复机器人
      添加评论
    3. Motorola Xoom 2 Battery Replacement: 步骤 7 中的图像 1,3 Motorola Xoom 2 Battery Replacement: 步骤 7 中的图像 2,3 Motorola Xoom 2 Battery Replacement: 步骤 7 中的图像 3,3
      • Lifting gently from the bottom with a spudger, first disconnect the three pin connector from the tablet.
      • After disconnecting the three pin connector, remove the two pin battery connector by lifting gently from the bottom with a spudger.
      • Be careful not to use too much force! The connectors used are made of soft plastic and can break easily.
      询问修复机器人
      添加评论
    4. Motorola Xoom 2 Battery Replacement: 步骤 8 中的图像 1,2 Motorola Xoom 2 Battery Replacement: 步骤 8 中的图像 2,2
      • Using the opening picks, carefully lift the battery and remove it from the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
1指南评论
Looks great, loving all the work you guys
Enrique Escobar - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 980
