跳转到主内容
加入维修社区 - 创建账户
Motorola V276 Keypad Replacement
你所需要的
  1. Motorola V276 Keypad Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
    询问修复机器人
    添加评论
  2. Motorola V276 Keypad Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
    询问修复机器人
    添加评论
  3. Motorola V276 Keypad Replacement: 步骤 3 中的图像 1,2 Motorola V276 Keypad Replacement: 步骤 3 中的图像 2,2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
    询问修复机器人
    添加评论
  4. Motorola V276 Keypad Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Use a spudger to remove the rubber plug from the upper left corner of the back of the phone.
    询问修复机器人
    添加评论
  5. Motorola V276 Keypad Replacement: 步骤 5 中的图像 1,1
    • Use a Torx T6 screwdriver to remove the 4 screws that secure the back plate of the phone.
    询问修复机器人
    添加评论
  6. Motorola V276 Keypad Replacement: 步骤 6 中的图像 1,3 Motorola V276 Keypad Replacement: 步骤 6 中的图像 2,3 Motorola V276 Keypad Replacement: 步骤 6 中的图像 3,3
    • Three tabs will hold the back plastic plate in.
    • To remove the back plate, pull the tabs towards the outside of the phone and lift the plate up simultaneously
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
    询问修复机器人
    添加评论
  7. Motorola V276 Keypad Replacement: 步骤 7 中的图像 1,3 Motorola V276 Keypad Replacement: 步骤 7 中的图像 2,3 Motorola V276 Keypad Replacement: 步骤 7 中的图像 3,3
    • Use a spudger to remove the ribbon cable from the motherboard.
    • Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function
    询问修复机器人
    添加评论
  8. Motorola V276 Keypad Replacement: 步骤 8 中的图像 1,1
    • Gently peel back the motherboard from the main part of the phone.
    询问修复机器人
    添加评论
  9. Motorola V276 Keypad Replacement, Keypad: 步骤 9 中的图像 1,1
    • Peel back keypad starting from the top of the phone
    • You can clean or replace the keypad once you have removed it from the phone
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
团队
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G96
4 名成员
创作了37篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 1,215
