跳转到主内容
加入维修社区 - 创建账户
Motorola RAZR2 v9m Keypad Replacement
你所需要的
    1. Motorola RAZR2 v9m Keypad Replacement, Battery: 步骤 1 中的图像 1,2 Motorola RAZR2 v9m Keypad Replacement, Battery: 步骤 1 中的图像 2,2
      • Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
      询问修复机器人
      添加评论
    2. Motorola RAZR2 v9m Keypad Replacement: 步骤 2 中的图像 1,3 Motorola RAZR2 v9m Keypad Replacement: 步骤 2 中的图像 2,3 Motorola RAZR2 v9m Keypad Replacement: 步骤 2 中的图像 3,3
      • Pinch the top and bottom edges of the panel and pull it away from the RAZR2.
      • The rear panel uses four small hooks to hold it in place. If the panel will not easily pull away, slide the panel more toward the hinge.
      询问修复机器人
      添加评论
    3. Motorola RAZR2 v9m Keypad Replacement: 步骤 3 中的图像 1,2 Motorola RAZR2 v9m Keypad Replacement: 步骤 3 中的图像 2,2
      • Gently pull the white plastic tab to lift the battery away from the RAZR2.
      • The white plastic tab is attached to the phone. Only pull it enough to expose the edges of the battery.
      询问修复机器人
      添加评论
    4. Motorola RAZR2 v9m Keypad Replacement: 步骤 4 中的图像 1,2 Motorola RAZR2 v9m Keypad Replacement: 步骤 4 中的图像 2,2
      • To remove the battery, grasp its edges pull away from the phone.
      • When installing a new battery, be sure the metal contacts on the phone line up with the ones on the battery.
      询问修复机器人
      添加评论
    1. Motorola RAZR2 v9m Keypad Replacement, Keypad: 步骤 5 中的图像 1,3 Motorola RAZR2 v9m Keypad Replacement, Keypad: 步骤 5 中的图像 2,3 Motorola RAZR2 v9m Keypad Replacement, Keypad: 步骤 5 中的图像 3,3
      • Flip the RAZR2 open with the battery compartment facing you.
      • Pull the white battery tab away from the phone to reveal a small black gap in the battery compartment.
      • Place the spudger into this gap. Rest the spudger against the black plastic inside of the gap.
      询问修复机器人
      添加评论
    2. Motorola RAZR2 v9m Keypad Replacement: 步骤 6 中的图像 1,3 Motorola RAZR2 v9m Keypad Replacement: 步骤 6 中的图像 2,3 Motorola RAZR2 v9m Keypad Replacement: 步骤 6 中的图像 3,3
      • Rest the spudger/scewdriver between the top of the black plastic and the metal body of the phone and leaver the two apart to release the top clip on the keyboard.and the top of the keypad pops out from the RAZR2.
      询问修复机器人
      添加评论
    3. Motorola RAZR2 v9m Keypad Replacement: 步骤 7 中的图像 1,3 Motorola RAZR2 v9m Keypad Replacement: 步骤 7 中的图像 2,3 Motorola RAZR2 v9m Keypad Replacement: 步骤 7 中的图像 3,3
      • Use a plastic opening tool to gently pry one side of the keypad away from the RAZR2.
      • There are 2 clips on the side of the keypad. In total, there are 8 clips holding the keypad to the phone.
      询问修复机器人
      添加评论
    4. Motorola RAZR2 v9m Keypad Replacement: 步骤 8 中的图像 1,3 Motorola RAZR2 v9m Keypad Replacement: 步骤 8 中的图像 2,3 Motorola RAZR2 v9m Keypad Replacement: 步骤 8 中的图像 3,3
      • Lift the keypad away from the phone.
      • When reassembling, gently squeeze the sides of the keypad until the keypad has a slight bow running down the middle from top to bottom, like a playing card. This will ensure that it slides easily into place. Take care not to damage any of the 8 clips.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 29
总计 1,720
