跳转到主内容
加入维修社区 - 创建账户
Motorola RAZR2 v9m Camera Replacement
你所需要的
    1. Motorola RAZR2 v9m Camera Replacement, Battery: 步骤 1 中的图像 1,2 Motorola RAZR2 v9m Camera Replacement, Battery: 步骤 1 中的图像 2,2
      • Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
      询问修复机器人
      添加评论
    2. Motorola RAZR2 v9m Camera Replacement: 步骤 2 中的图像 1,3 Motorola RAZR2 v9m Camera Replacement: 步骤 2 中的图像 2,3 Motorola RAZR2 v9m Camera Replacement: 步骤 2 中的图像 3,3
      • Pinch the top and bottom edges of the panel and pull it away from the RAZR2.
      • The rear panel uses four small hooks to hold it in place. If the panel will not easily pull away, slide the panel more toward the hinge.
      询问修复机器人
      添加评论
    3. Motorola RAZR2 v9m Camera Replacement: 步骤 3 中的图像 1,2 Motorola RAZR2 v9m Camera Replacement: 步骤 3 中的图像 2,2
      • Gently pull the white plastic tab to lift the battery away from the RAZR2.
      • The white plastic tab is attached to the phone. Only pull it enough to expose the edges of the battery.
      询问修复机器人
      添加评论
    4. Motorola RAZR2 v9m Camera Replacement: 步骤 4 中的图像 1,2 Motorola RAZR2 v9m Camera Replacement: 步骤 4 中的图像 2,2
      • To remove the battery, grasp its edges pull away from the phone.
      • When installing a new battery, be sure the metal contacts on the phone line up with the ones on the battery.
      询问修复机器人
      添加评论
    1. Motorola RAZR2 v9m Camera Replacement, Camera: 步骤 5 中的图像 1,3 Motorola RAZR2 v9m Camera Replacement, Camera: 步骤 5 中的图像 2,3 Motorola RAZR2 v9m Camera Replacement, Camera: 步骤 5 中的图像 3,3
      • Flip open the RAZR2 with the keypad and main LCD facing you.
      • Insert a spudger into the small gap above the plastic screen.
      • Gently pry the screen away from the phone.
      询问修复机器人
      添加评论
    2. Motorola RAZR2 v9m Camera Replacement: 步骤 6 中的图像 1,3 Motorola RAZR2 v9m Camera Replacement: 步骤 6 中的图像 2,3 Motorola RAZR2 v9m Camera Replacement: 步骤 6 中的图像 3,3
      • The plastic screen is held in place by adhesive. Run the spudger along both sides of the screen to separate it from the RAZR2.
      • Lift the screen away from the phone.
      询问修复机器人
      添加评论
    3. Motorola RAZR2 v9m Camera Replacement: 步骤 7 中的图像 1,2 Motorola RAZR2 v9m Camera Replacement: 步骤 7 中的图像 2,2
      • Remove the four 2-mm T5 Torx screws
      询问修复机器人
      添加评论
    4. Motorola RAZR2 v9m Camera Replacement: 步骤 8 中的图像 1,2 Motorola RAZR2 v9m Camera Replacement: 步骤 8 中的图像 2,2
      • Use a plastic opening tool to pry the top end of the metal frame away from the RAZR2.
      询问修复机器人
      添加评论
    5. Motorola RAZR2 v9m Camera Replacement: 步骤 9 中的图像 1,3 Motorola RAZR2 v9m Camera Replacement: 步骤 9 中的图像 2,3 Motorola RAZR2 v9m Camera Replacement: 步骤 9 中的图像 3,3
      • Insert a plastic opening tool under the metal frame at the hinge of the RAZR2.
      • Gently pry the hinge portion of the metal frame away from the phone.
      • The metal frame is latched to the phone on the corner closest to the clear and end call buttons. Pry this part of the frame away last.
      询问修复机器人
      添加评论
    6. Motorola RAZR2 v9m Camera Replacement: 步骤 10 中的图像 1,3 Motorola RAZR2 v9m Camera Replacement: 步骤 10 中的图像 2,3 Motorola RAZR2 v9m Camera Replacement: 步骤 10 中的图像 3,3
      • Lift the frame away from the phone.
      • When reassembling, insert the latch on the metal frame into the phone before inserting any other part of the frame.
      询问修复机器人
      添加评论
    7. Motorola RAZR2 v9m Camera Replacement: 步骤 11 中的图像 1,3 Motorola RAZR2 v9m Camera Replacement: 步骤 11 中的图像 2,3 Motorola RAZR2 v9m Camera Replacement: 步骤 11 中的图像 3,3
      • Use the plastic opening tool to gently pry the motherboard cable out of its socket.
      询问修复机器人
      添加评论
    8. Motorola RAZR2 v9m Camera Replacement: 步骤 12 中的图像 1,3 Motorola RAZR2 v9m Camera Replacement: 步骤 12 中的图像 2,3 Motorola RAZR2 v9m Camera Replacement: 步骤 12 中的图像 3,3
      • Use the plastic opening tool to gently pry the LCD cable out of its socket.
      询问修复机器人
      添加评论
    9. Motorola RAZR2 v9m Camera Replacement: 步骤 13 中的图像 1,3 Motorola RAZR2 v9m Camera Replacement: 步骤 13 中的图像 2,3 Motorola RAZR2 v9m Camera Replacement: 步骤 13 中的图像 3,3
      • Use the plastic opening tool to gently pry the camera cable out of its socket.
      询问修复机器人
      添加评论
    10. Motorola RAZR2 v9m Camera Replacement: 步骤 14 中的图像 1,3 Motorola RAZR2 v9m Camera Replacement: 步骤 14 中的图像 2,3 Motorola RAZR2 v9m Camera Replacement: 步骤 14 中的图像 3,3
      • Use a plastic opening tool to gently pry the camera assembly away from the RAZR2.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 1,344
