跳转到主内容
Motorola Moto E4 Plus Daughterboard Replacement
你所需要的
  1. Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: 步骤 1 中的图像 1,3 Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: 步骤 1 中的图像 2,3 Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: 步骤 1 中的图像 3,3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Daughterboard Replacement: 步骤 2 中的图像 1,2 Motorola Moto E4 Plus Daughterboard Replacement: 步骤 2 中的图像 2,2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe screws: 步骤 3 中的图像 1,1
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Daughterboard Replacement, Release the midframe clips: 步骤 4 中的图像 1,2 Motorola Moto E4 Plus Daughterboard Replacement, Release the midframe clips: 步骤 4 中的图像 2,2
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe: 步骤 5 中的图像 1,2 Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe: 步骤 5 中的图像 2,2
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the battery: 步骤 6 中的图像 1,2 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the battery: 步骤 6 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the antenna: 步骤 7 中的图像 1,2 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the antenna: 步骤 7 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the antenna cable from its daughterboard socket.
  8. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: 步骤 8 中的图像 1,3 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: 步骤 8 中的图像 2,3 Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: 步骤 8 中的图像 3,3
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its daughterboard socket.
    • Pry up and disconnect the fingerprint sensor cable next to it from the daughterboard.
  9. Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard screws: 步骤 9 中的图像 1,1
    • Remove the two 3.2 mm long T3 screws securing the daughterboard.
  10. Motorola Moto E4 Plus Daughterboard Replacement, Loosen the daughterboard: 步骤 10 中的图像 1,2 Motorola Moto E4 Plus Daughterboard Replacement, Loosen the daughterboard: 步骤 10 中的图像 2,2
    • Insert the point of a spudger under the bottom right corner of the daughterboard and pry up to loosen the daughterboard.
  11. Motorola Moto E4 Plus Daughterboard Replacement, Loosen the vibration motor: 步骤 11 中的图像 1,2 Motorola Moto E4 Plus Daughterboard Replacement, Loosen the vibration motor: 步骤 11 中的图像 2,2
    • Insert the point of a spudger underneath the vibration motor and pry upwards to loosen it.
  12. Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard: 步骤 12 中的图像 1,2 Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard: 步骤 12 中的图像 2,2
    • Grasp the daughterboard by the edges and lift it out of its recess.
    • Remove the daughterboard. The vibration motor will be attached to it.
结论
2等其他人完成本指南。
Arthur Shi
于01/03/18注册
252,816 声望
创作了526篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,471
