跳转到主内容
Motorola Moto E4 Plus Battery Replacement
你所需要的
  1. Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 步骤 1 中的图像 1,3 Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 步骤 1 中的图像 2,3 Motorola Moto E4 Plus Battery Replacement, Remove the back cover: 步骤 1 中的图像 3,3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Battery Replacement: 步骤 2 中的图像 1,2 Motorola Moto E4 Plus Battery Replacement: 步骤 2 中的图像 2,2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Battery Replacement, Midframe: 步骤 3 中的图像 1,1
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Battery Replacement: 步骤 4 中的图像 1,2 Motorola Moto E4 Plus Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Battery Replacement: 步骤 5 中的图像 1,3 Motorola Moto E4 Plus Battery Replacement: 步骤 5 中的图像 2,3 Motorola Moto E4 Plus Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the battery cover.
  6. Motorola Moto E4 Plus Battery Replacement: 步骤 6 中的图像 1,2 Motorola Moto E4 Plus Battery Replacement: 步骤 6 中的图像 2,2
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Battery Replacement: 步骤 7 中的图像 1,2 Motorola Moto E4 Plus Battery Replacement: 步骤 7 中的图像 2,2
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Battery Replacement: 步骤 8 中的图像 1,2 Motorola Moto E4 Plus Battery Replacement: 步骤 8 中的图像 2,2
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Battery Replacement, Battery Disconnect: 步骤 9 中的图像 1,2 Motorola Moto E4 Plus Battery Replacement, Battery Disconnect: 步骤 9 中的图像 2,2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Battery Replacement, Battery: 步骤 10 中的图像 1,3 Motorola Moto E4 Plus Battery Replacement, Battery: 步骤 10 中的图像 2,3 Motorola Moto E4 Plus Battery Replacement, Battery: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to peel the ends of the two pull tabs off of the bottom edge of the battery.
  11. Motorola Moto E4 Plus Battery Replacement: 步骤 11 中的图像 1,3 Motorola Moto E4 Plus Battery Replacement: 步骤 11 中的图像 2,3 Motorola Moto E4 Plus Battery Replacement: 步骤 11 中的图像 3,3
    • Pull out the left adhesive strip by steadily pulling the left tab at a flat angle.
    • If the adhesive strip rips, grab and twist the remaining stub around the tip of a pair of tweezers a couple of times and then continue pulling.
    • Repeat the same process for the right adhesive strip.
  12. Motorola Moto E4 Plus Battery Replacement: 步骤 12 中的图像 1,2 Motorola Moto E4 Plus Battery Replacement: 步骤 12 中的图像 2,2
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape.
    • In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery.
    • Press the new battery firmly into place for 5-10 seconds.
结论
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
19等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
204,989 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 114
总计 22,404
