跳转到主内容
加入维修社区 - 创建账户
Motorola Moto E Display Assembly Replacement
你所需要的
    1. Motorola Moto E Display Assembly Replacement, Motherboard: 步骤 1 中的图像 1,1
      • Turn off the device before beginning.
      • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
      • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
      • You should hear a snapping sound at each corner.
      询问修复机器人
      添加评论
    2. Motorola Moto E Display Assembly Replacement: 步骤 2 中的图像 1,1
      • Unscrew the 14 4mm screws using a T4 Torx screwdriver.
      询问修复机器人
      添加评论
    3. Motorola Moto E Display Assembly Replacement: 步骤 3 中的图像 1,1
      • Using a plastic opening tool, pry up on the edges of the plastic back cover.
      • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
      询问修复机器人
      添加评论
    4. Motorola Moto E Display Assembly Replacement: 步骤 4 中的图像 1,1
      • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
      • Do not touch the connections to the battery in the red square on the picture.
      询问修复机器人
      添加评论
    5. Motorola Moto E Display Assembly Replacement: 步骤 5 中的图像 1,1
      • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
      • Move the battery and cover away from the motherboard.
      询问修复机器人
      添加评论
    6. Motorola Moto E Display Assembly Replacement: 步骤 6 中的图像 1,1
      • Remove the three 1 mm screws using a T4 Torx screwdriver.
      询问修复机器人
      添加评论
    7. Motorola Moto E Display Assembly Replacement: 步骤 7 中的图像 1,1
      • Lift up on the white plastic mount.
      • Pull the orange ribbon cable out gently.
      询问修复机器人
      添加评论
    8. Motorola Moto E Display Assembly Replacement: 步骤 8 中的图像 1,2 Motorola Moto E Display Assembly Replacement: 步骤 8 中的图像 2,2
      • Gently pull the black ribbon cable out.
      询问修复机器人
      添加评论
    9. Motorola Moto E Display Assembly Replacement: 步骤 9 中的图像 1,1
      • Using the metal spudger, pry the motherboard away from the screen assembly.
      添加评论
    1. Motorola Moto E Display Assembly Replacement, Display Assembly: 步骤 10 中的图像 1,1
      • Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
      • The phone will be extremely hot. Avoid direct contact with metal pieces.
      询问修复机器人
      添加评论
    2. Motorola Moto E Display Assembly Replacement: 步骤 11 中的图像 1,1
      • Gently slide the metal spudger underneath the screen and pry it away from the backing.
      • Move the metal spudger under the digitizer and along the entire length of the phone to separate the screen from the adhesive.
      • If the screen was broken, glass shards may come off of the screen and puncture skin.
      询问修复机器人
      添加评论
    3. Motorola Moto E Display Assembly Replacement: 步骤 12 中的图像 1,1
      • Continue to heat and separate until the screen comes completely apart from the rest of the phone.
      询问修复机器人
      添加评论
    4. Motorola Moto E Display Assembly Replacement: 步骤 13 中的图像 1,1
      • To put the new screen on, press the new screen and digitizer into place, and then reapply heat to adhere the new screen.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
24等其他人完成本指南。
Alex Craig
于03/11/15注册
2,611 声望
创作了5篇指南
团队
Colorado Springs, Team 5-7, Panko Spring 2015 Colorado Springs, Team 5-7, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G7
2 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 49
总计 32,137
