跳转到主内容
加入维修社区 - 创建账户
Motorola Moto E Battery Replacement
你所需要的
  1. Motorola Moto E  Battery Replacement, Battery: 步骤 1 中的图像 1,2 Motorola Moto E  Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off the device before beginning the battery replacement.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
    询问修复机器人
    添加评论
  2. Motorola Moto E  Battery Replacement: 步骤 2 中的图像 1,1
    • Unscrew all 14- 4mm screws located on the back part of the phone using a T4 Torx bit.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
    询问修复机器人
    添加评论
  3. Motorola Moto E  Battery Replacement: 步骤 3 中的图像 1,1
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
    询问修复机器人
    添加评论
  4. Motorola Moto E  Battery Replacement: 步骤 4 中的图像 1,1
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
    询问修复机器人
    添加评论
  5. Motorola Moto E  Battery Replacement: 步骤 5 中的图像 1,1
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
    询问修复机器人
    添加评论
  6. Motorola Moto E  Battery Replacement: 步骤 6 中的图像 1,1
    • Lift gently on the battery using the metal spudger tool.
    • The battery is stuck to the plastic case with double sided tape. You should hear the battery peeling away from the cover as you are pulling on it.
    • Obtain a new battery and place it into the plastic casing using double sided tape or whatever is provided with the new battery.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
36等其他人完成本指南。
Alex Craig
于03/11/15注册
2,611 声望
创作了5篇指南
团队
Colorado Springs, Team 5-7, Panko Spring 2015 Colorado Springs, Team 5-7, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G7
2 名成员
创作了20篇指南
7指南评论
another quite superb guide from ifixit ....
I'm not surprised either as the guides on here are far and away the best available online.
keep up the good work contributors!
carol - 回复 分享
is it possible to fit Moto 2 gen battery into Moto 1 gen phone ?
Clement Santhosh - 回复 分享
This worked very well for me, many thanks!
Tony Franks - 回复 分享
which battery type or brand should we purchase????????
hridaya123.praja - 回复 分享
Excellent, clear instructions!
Gerald Griffin - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 121
总计 79,414
