跳转到主内容
Motorola Moto 360 LCD Display Replacement
你所需要的
  1. Motorola Moto 360 LCD Display Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 LCD Display Replacement: 步骤 3 中的图像 1,2 Motorola Moto 360 LCD Display Replacement: 步骤 3 中的图像 2,2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 LCD Display Replacement: 步骤 4 中的图像 1,1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
  4. Motorola Moto 360 LCD Display Replacement, O-Ring: 步骤 5 中的图像 1,2 Motorola Moto 360 LCD Display Replacement, O-Ring: 步骤 5 中的图像 2,2
    • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
  5. Motorola Moto 360 LCD Display Replacement: 步骤 6 中的图像 1,1
    • Pinch the green rubber O-Ring and slide it off of the watch.
    • The O-Ring is delicate and is easily severed. Use care around sharp objects.
  6. Motorola Moto 360 LCD Display Replacement, LCD Display: 步骤 7 中的图像 1,1
    • Set the Moto 360 face up on a flat surface.
    • Place the iOpener on the face of the device screen.
  7. Motorola Moto 360 LCD Display Replacement: 步骤 8 中的图像 1,2 Motorola Moto 360 LCD Display Replacement: 步骤 8 中的图像 2,2
    • Gently slide the opening pick between the screen and the metal casing.
    • Work your way around the face of the screen, loosening the adhesive.
  8. Motorola Moto 360 LCD Display Replacement: 步骤 9 中的图像 1,2 Motorola Moto 360 LCD Display Replacement: 步骤 9 中的图像 2,2
    • Detach the copper ribbon connecting the motherboard to the display.
    • For reassembly, attach copper ribbon where it is marked.
    • The copper ribbon is fragile and easily disconnects. Remember where it goes so as to reconnect it properly.
  9. Motorola Moto 360 LCD Display Replacement: 步骤 10 中的图像 1,1
    • Slide the display out of the metal casing.
结论
15等其他人完成本指南。
Cole Twitchell
于01/30/15注册
1,688 声望
创作了2篇指南
团队
Cal Poly, Team 17-32, Amido Winter 2015 Cal Poly, Team 17-32, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G32
4 名成员
创作了18篇指南
7条评论
Good morning,
It is possible to replace the display unit for the Moto 360 2nd with 1.56" display?
Thanks in advance and best regards,
Stephan
Stephan Müller - 回复
Were could i buy a new lcd screen for the moto 360 1st gen??
Sebastian Galvan - 回复
hey mate you can buy one from aliexpress aliexpress moto 360 screen see link below
https://goo.gl/ZSMTVW
Faddy Oraha -
Where can I get a LCD display for a Moto 360 2 gen 42mm. Thanks hope you can help
Glenn Patoska - 回复
Bonjour,
Où est-il possible de trouver des pièces détachées ?
Le fond du boitier.
Merci de votre réponse.
DOGUE - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 24
总计 21,502
