简介
Stop! Don't cook your Moto 360 and go at it with an oyster knife just to replace the battery. Just pop out these four fasteners to release the case back.
Note: the guide for removing the strap shows a watch with the back cover ripped off. Don't do it! Just remove the strap and go to the next step.
你所需要的
Locate the spring-loaded pin that attaches the wrist strap to the watch.
There is a tiny groove on the end of the pin. This is where you will place the tweezers.
Locate the rectangular end of the fastener inside the wrist strap mounting pocket.
Push the point of the pin in behind the fastener and pry it out. There is a notch near the end of the fastener which will engage the pin. Once the end pops out, the fastener will slide out of the slot easliy. Repeat to remove all four of them.
That's it. Now the two halves of the watch can be easily separated by just pulling gently with your fingers.
18等其他人完成本指南。
9条评论
I lost my fasteners... where can I buy more?
One misleading thing about this guide: pictures show the back cover taken off, while in fact you don't need to do this -- just take out the fasteners.
Absolutely correct, you don't need to heat or take the back off. I will say though that getting those clips out was damnably fiddly for me.
ou peut acheter Case Locking Fastener Replacement pour moto360 mon bracelet tien pas
svp chez besoin case locking fastener
don't remove the back!
follow this video for removing the locking pins.
I did it, so can you!
