跳转到主内容
加入维修社区 - 创建账户
Motorola Droid RAZR HD Front Panel Replacement
你所需要的
    1. Motorola Droid RAZR HD Front Panel Replacement, Front Panel Assembly: 步骤 1 中的图像 1,1
      • Power off the device before disassembly to avoid damage or harm from electrical surges.
      • Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
      询问修复机器人
      添加评论
    2. Motorola Droid RAZR HD Front Panel Replacement: 步骤 2 中的图像 1,1
      • Holding the device in your hand, push the screen towards the top of the phone until it disconnects from the base of the phone.
      询问修复机器人
      添加评论
    3. Motorola Droid RAZR HD Front Panel Replacement: 步骤 3 中的图像 1,1
      • Use a plastic opening tool to lift the screen from the phone.
      • Do not try to completely detach the screen; cables are still connected to the device and can be damaged.
      询问修复机器人
      添加评论
    4. Motorola Droid RAZR HD Front Panel Replacement: 步骤 4 中的图像 1,2 Motorola Droid RAZR HD Front Panel Replacement: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to remove the yellow tape covering the lcd/digitizer cable connector.
      • Carefully lift up the black locking tab to release the lcd/digitizer cable.
      • The cable connector is located on the bottom right section of the phone.
      询问修复机器人
      添加评论
    5. Motorola Droid RAZR HD Front Panel Replacement: 步骤 5 中的图像 1,1
      • Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
      • This connector is located on the top right section of the phone.
      • Use tweezers to lift the black bar on top of the ZIF connector.
      • Pull the ribbon cable out of the connector with tweezers.
      • Now that there are no cables connecting the screen to the motherboard, remove the screen.
      询问修复机器人
      添加评论
    1. Motorola Droid RAZR HD Front Panel Replacement, Front Panel: 步骤 6 中的图像 1,2 Motorola Droid RAZR HD Front Panel Replacement, Front Panel: 步骤 6 中的图像 2,2
      在这个步骤中使用的工具:
      • Remove the two 2.0mm T4 Torx screws near the top of the screen.
      • Remove the metal plate protecting the front camera and ear speaker with tweezers.
      询问修复机器人
      添加评论
    2. Motorola Droid RAZR HD Front Panel Replacement: 步骤 7 中的图像 1,2 Motorola Droid RAZR HD Front Panel Replacement: 步骤 7 中的图像 2,2
      • Using a plastic openining tool, lift up the front camera and ear speaker assembly.
      • Remove the assembly with tweezers.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 4-4, Maness Spring 2015 Cal Poly, Team 4-4, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G4
5 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 2,016
