跳转到主内容
加入维修社区 - 创建账户
Motorola Defy XT Logic Board Replacement
你所需要的
    1. Motorola Defy XT Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,1
      • Wedge the opening tool in-between the back cover and the body of the phone in the opening denoted by the arrow.
      询问修复机器人
      添加评论
    2. Motorola Defy XT Logic Board Replacement: 步骤 2 中的图像 1,1
      • Once wedged in the opening, slide the opening tool around the side of the phone and remove the back cover, setting it aside.
      询问修复机器人
      添加评论
    3. Motorola Defy XT Logic Board Replacement: 步骤 3 中的图像 1,1
      • Insert the opening tool between the battery and the battery holder and wedge the battery out.
      询问修复机器人
      添加评论
    4. Motorola Defy XT Logic Board Replacement: 步骤 4 中的图像 1,1
      • Open the plastic cover with your finger to expose the SD card.
      • Use the opening tool to grab the edge of the SD card and pull it straight out.
      询问修复机器人
      添加评论
    5. Motorola Defy XT Logic Board Replacement: 步骤 5 中的图像 1,1
      • Remove the six 6mm T4 screws with the T4 torque driver.
      询问修复机器人
      添加评论
    6. Motorola Defy XT Logic Board Replacement: 步骤 6 中的图像 1,1
      • Pop out the volume button with the plastic opening tool.
      询问修复机器人
      添加评论
    7. Motorola Defy XT Logic Board Replacement: 步骤 7 中的图像 1,2 Motorola Defy XT Logic Board Replacement: 步骤 7 中的图像 2,2
      • Wedge the plastic opening tool in-between the plastic layer and the front cover.
      • Do not completely separate the two pieces to avoid damaging the ribbon cable inside.
      询问修复机器人
      添加评论
    8. Motorola Defy XT Logic Board Replacement: 步骤 8 中的图像 1,1
      • Carefully separate the bottom piece from the top plastic piece.
      • Disconnect the ribbon cable connecting the display to the logic board by firmly pulling the cable straight outward.
      • The screen can now be removed.
      询问修复机器人
      添加评论
    9. Motorola Defy XT Logic Board Replacement: 步骤 9 中的图像 1,1
      • Separate the logic board and the display cover from the back cover and orient the logic board so the camera faces toward you.
      • Disconnect the back cover by wedging the plastic opening tool in between the motherboard and the connector and prying outward.
      询问修复机器人
      添加评论
    10. Motorola Defy XT Logic Board Replacement: 步骤 10 中的图像 1,1
      • Flip the logic board and display cover over so the camera faces away from you.
      • Bend the two halves of the device away from you to pry the final ribbon connector off the logic board.
      • The ribbon connector is bonded to the logic board with adhesive, simply pull it to break the glue bond.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
No Name
于04/21/13注册
25 声望
撰写一个指南
2指南评论
Imbecells give up DEMONIC HOLD PRAISE THE LORD HE HAS COME 4 U
True Seminary - 回复 分享
idoits have faith like a lil ole mustard seed
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 33
总计 1,730
