跳转到主内容
加入维修社区 - 创建账户
Motorola C261 Screen Replacement
你所需要的
  1. Motorola C261 Screen Replacement, Place Phone: 步骤 1 中的图像 1,1
    • Place the phone with the screen facedown on a flat surface.
    询问修复机器人
    添加评论
  2. Motorola C261 Screen Replacement, Latch and Back Cover: 步骤 2 中的图像 1,2 Motorola C261 Screen Replacement, Latch and Back Cover: 步骤 2 中的图像 2,2
    • Pinch the latch upwards towards the top of the phone.
    • Lift the back cover of the phone.
    • There are tabs on the bottom end of the battery cover that the cover pivots about.
    询问修复机器人
    添加评论
  3. Motorola C261 Screen Replacement, Remove Battery: 步骤 3 中的图像 1,2 Motorola C261 Screen Replacement, Remove Battery: 步骤 3 中的图像 2,2
    • Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
    询问修复机器人
    添加评论
  4. Motorola C261 Screen Replacement, Screws in Rear Housing: 步骤 4 中的图像 1,1
    • Remove the four 8.5 mm screws from under the battery cover with a T4 Torx screwdriver.
    • Remove the two 8.5 mm screws from the top of the phone with a T4 Torx screwdriver.
    询问修复机器人
    添加评论
  5. Motorola C261 Screen Replacement, Rear Housing: 步骤 5 中的图像 1,2 Motorola C261 Screen Replacement, Rear Housing: 步骤 5 中的图像 2,2
    • Using the plastic pry tool remove the rear housing from the rest of the phone. You may have to pry around all edges of the phone, not just the edge shown.
    • When you remove the rear housing, the rubber cover for the headphone jack/charge port may fall out. If not, remove it.
    询问修复机器人
    添加评论
  6. Motorola C261 Screen Replacement, Spacers: 步骤 6 中的图像 1,2 Motorola C261 Screen Replacement, Spacers: 步骤 6 中的图像 2,2
    • Remove the small black circular rubber spacer.
    • Remove the white rubber spacer.
    • These pieces are small and easy to lose, especially the black one. Set them somewhere safe!
    询问修复机器人
    添加评论
  7. Motorola C261 Screen Replacement, Motherboard and Front Housing: 步骤 7 中的图像 1,2 Motorola C261 Screen Replacement, Motherboard and Front Housing: 步骤 7 中的图像 2,2
    • Gently remove the motherboard assembly from the front housing.
    • Now, the front housing is free to be replaced, as well as the cosmetic keypad.
    询问修复机器人
    添加评论
  8. Motorola C261 Screen Replacement, Clips: 步骤 8 中的图像 1,2 Motorola C261 Screen Replacement, Clips: 步骤 8 中的图像 2,2
    • Remove the 2 clips from the sides of the phone, just below the screen with the pry tool.
    询问修复机器人
    添加评论
  9. Motorola C261 Screen Replacement, Button Circuit Board: 步骤 9 中的图像 1,2 Motorola C261 Screen Replacement, Button Circuit Board: 步骤 9 中的图像 2,2
    • The circuit board for the buttons is now free to be removed and replaced.
    询问修复机器人
    添加评论
  10. Motorola C261 Screen Replacement, Front Speaker: 步骤 10 中的图像 1,2 Motorola C261 Screen Replacement, Front Speaker: 步骤 10 中的图像 2,2
    • Pry under the display screen, around each edge until it comes loose from the circuit board.
    • You are removing the black plastic piece that holds the button circuit board. The piece has an aluminum frame around it. The two pieces will be removed together and don't need to be separated.
    询问修复机器人
    添加评论
  11. Motorola C261 Screen Replacement, Removing Framework: 步骤 11 中的图像 1,1
    • Gently remove the plastic and metal framework of the phone by lifting it up.
    询问修复机器人
    添加评论
  12. Motorola C261 Screen Replacement, Removing Screen Ribbon Connection: 步骤 12 中的图像 1,2 Motorola C261 Screen Replacement, Removing Screen Ribbon Connection: 步骤 12 中的图像 2,2
    • Use the prying tool to remove the connection between the display screen and the the main circuit board.
    • The ribbon is not removed. It is instead connected to the circuit board by a set of circuit connectors.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Jason
于10/23/14注册
305 声望
创作了3篇指南
团队
Michigan Tech, Team 1-6, Lauer Fall 2014 Michigan Tech, Team 1-6, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G6
3 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 27
总计 533
