跳转到主内容
加入维修社区 - 创建账户
Motorola Atrix HD Battery Replacement
你所需要的
    1. Motorola Atrix HD Battery Replacement, Battery: 步骤 1 中的图像 1,3 Motorola Atrix HD Battery Replacement, Battery: 步骤 1 中的图像 2,3 Motorola Atrix HD Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • Before disassembling the phone, remove the SIM card and the MICRO-SD card, if equipped.
      • Begin taking apart the device by prying apart the back cover from the assembly using the plastic opening tool.
      • Continue working around the edge of the phone using the plastic opening tool.
      • When all the edges have been lifted apart, use your hands or plastic opening tool to peel the back plate from the battery. There are small adhesive strips between the back cover and the battery, so take care not to crack the back cover while prying open.
      询问修复机器人
      添加评论
    2. Motorola Atrix HD Battery Replacement: 步骤 2 中的图像 1,1
      • The adhesive strips are shown in the orange boxes. Be sure not to use too much force to pull off the back cover, or you may risk snapping the back cover.
      询问修复机器人
      添加评论
    3. Motorola Atrix HD Battery Replacement: 步骤 3 中的图像 1,3 Motorola Atrix HD Battery Replacement: 步骤 3 中的图像 2,3 Motorola Atrix HD Battery Replacement: 步骤 3 中的图像 3,3
      在这个步骤中使用的工具:
      • Remove the red rubber screw cover with a pair of tweezers
      询问修复机器人
      添加评论
    4. Motorola Atrix HD Battery Replacement: 步骤 4 中的图像 1,2 Motorola Atrix HD Battery Replacement: 步骤 4 中的图像 2,2
      • Use the T-5 Torx bit to remove the two silver 3.3 mm screws with integrated washers.
      询问修复机器人
      添加评论
    5. Motorola Atrix HD Battery Replacement: 步骤 5 中的图像 1,1
      • Lift the battery leads to the upward position. The ribbon cable is very thin, be gentle.
      询问修复机器人
      添加评论
    6. Motorola Atrix HD Battery Replacement: 步骤 6 中的图像 1,3 Motorola Atrix HD Battery Replacement: 步骤 6 中的图像 2,3 Motorola Atrix HD Battery Replacement: 步骤 6 中的图像 3,3
      • Use the plastic opening tool around the edges to loosen the battery.
      • Once the battery is loose, carefully lift from the bottom edge and remove the battery.
      询问修复机器人
      添加评论
    7. Motorola Atrix HD Battery Replacement: 步骤 7 中的图像 1,1
      • The battery may now be removed.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
UMass Dartmouth, Team 1-8, Miles Fall 2015 UMass Dartmouth, Team 1-8, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G8
3 名成员
创作了20篇指南
1指南评论
How do you calibrate it then? Lights up green dot, charges, won't work! Multi tester shows full power.
jvandeputte - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 42
总计 3,730
