简介
Follow this guide to replace the front camera in your Moto X Pure Edition.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
你所需要的
Prepare an iOpener and heat the back of the phone along its right edge for about five minutes. This will help soften the adhesive securing the back cover.
在这个步骤中使用的工具:Tweezers$4.99
Hold a pair of pointed tweezers closed, and insert them into the small hole on the edge of the back cover near the SIM card slot.
Use the tweezers to lift the cover up slightly, and slide an opening pick into the gap between the cover and the frame.
Prepare an iOpener and heat the back of the phone along its left edge for about five minutes. This will help soften the adhesive securing the rest of the back cover.
在这个步骤中使用的工具:Tesa 61395 Tape$8.95
Carefully pry the cover away from the phone.
First use tweezers and a spudger to peel and scrape away any remaining adhesive from both the back cover and the phone's chassis.
Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as Tesa 61395. Before installing the precut adhesive on the back cover, remove the metal insert. Install the adhesive, then replace the insert.
After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
Use the flat end of the nylon spudger to gently pry up on the front camera connector.
