简介
Use this guide to replace the screen assembly on your Moto G6 Plus, including the midframe which is glued to the display.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Make sure your replacement part includes both the display and the midframe—this guide does not cover separating the display from the midframe.
This procedure involves removing the battery, which should not be reused as it may be damaged during removal. Make sure to reassemble the phone with a new battery.
你所需要的
Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the right side of the top edge of the phone.
Press the tool into the hole to eject the tray.
If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
If the rear glass is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Use a Phillips driver to remove ten screws securing the upper plastic cover.
Seven 3.2 mm-long screws
Three 2.7 mm-long screws
Use the flat end of a spudger to pry up the battery connector and disconnect it.
Very carefully peel up all the black stickers covering the battery.
If possible, keep the tape intact so it can be reused during reassembly.
Prepare an iOpener and apply it directly to the battery for at least two minutes. Reheat and reapply the iOpener as needed.
Alternatively, apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
Use a Phillips #000 driver to remove six 3.2 mm-long screws securing the lower plastic cover.
Use the point of a spudger to pry the digitizer connecter straight up and out of its socket on the motherboard.
Carefully lift the top of the motherboard, keeping it clear of any cables and connectors.
Slide the motherboard toward the top of the phone to remove it from the midframe.
Use tweezers to lift the red microphone gasket out of its recess in the midframe.
5等其他人完成本指南。
