跳转到主内容
加入维修社区 - 创建账户
Monster DNA Wire Replacement
你所需要的
    1. Monster DNA Wire Replacement, Wire: 步骤 1 中的图像 1,1
      • Take off the ear cushions by pulling on the sides.
      询问修复机器人
      添加评论
    2. Monster DNA Wire Replacement: 步骤 2 中的图像 1,1
      • Use a Phillips #2 screwdriver to unscrew the three 5mm screws that secure the speaker cover.
      添加评论
    3. Monster DNA Wire Replacement: 步骤 3 中的图像 1,1
      • Use a plastic opening tool or a metal spudger to pry off the plate
      • Be careful as too much force may cause damage to your headphones.
      询问修复机器人
      添加评论
    4. Monster DNA Wire Replacement: 步骤 4 中的图像 1,1
      • Once the loose wire or wires are located on the back of the speaker, use a soldering iron to attach the loose wire back onto the speaker.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
UMass Dartmouth, Team S4-G5, Julie Spring 2017 UMass Dartmouth, Team S4-G5, Julie Spring 2017 的会员
UMASSD-JULIE-S17S4G5
4 名成员
创作了12篇指南
2指南评论
any ways on being able to know which side its on in particular without having to open both sides?
Finnlay Worchurst - 回复 分享
I broke the plate which holds the ear muffs on, by following these directions.
On Step 3, you have the spudger in the wrong location. You are supposed to put the prying bar or spudger before or after the silver ring which acts as a spacer for the speaker housing. I like to pry in the space between the silver ring and the audio jack.
Pics look good but you will have replace the one in step 3 showing the correct location to pry from. Others too will brake the same ring I did hence your warning about damage to the headphones if applying too much pressure.
Dan
Dan Daley - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 51
总计 4,447
