跳转到主内容
Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement
你所需要的
  1. Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Orient your saw sideways so that the blade is facing downwards.
  2. Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: 步骤 2 中的图像 1,3 Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: 步骤 2 中的图像 2,3 Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the nine 6 mm screws using a Torx T4 screwdriver.
    • Remove the single 8 mm screw at the bottom that attaches the panels together using a Torx T6 screwdriver.
    • Slowly pull and remove the front panel of the saw that connects to the blade side with your hand, and separate it from the motor.
  3. Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Slowly remove the battery from its slot with your hand while watching out for the spring below.
    • Remove the spring that is located under the battery compartment and set it aside for later.
  4. Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Carefully remove the rubber covers from the black and red wires of the battery with a pair of tweezers.
  5. Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: 步骤 5 中的图像 1,3 Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: 步骤 5 中的图像 2,3 Milwaukee Circular Saw 263020 B57A 2008 Battery Replacement: 步骤 5 中的图像 3,3
    • Carefully desolder and separate the wires from the battery compartment.
    • Gently pull the wires off with your hands being careful of the heat.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 83
