跳转到主内容
加入维修社区 - 创建账户
Midiman Oxygen 8 Keys Replacement
你所需要的
    1. Midiman Oxygen 8 Keys Replacement, Midiman Oxygen 8 Backplate Disassembly: 步骤 1 中的图像 1,2 Midiman Oxygen 8 Keys Replacement, Midiman Oxygen 8 Backplate Disassembly: 步骤 1 中的图像 2,2
      • Remove the 8 mm M3 Phillips head self tapping machine screws.
      • Several of the screws are in narrow, deep sockets; make sure to use an appropriate screw driver to remove them so as not to damage the cover during removal.
      • Remove all 13 of the back plate screws.
      询问修复机器人
      添加评论
    2. Midiman Oxygen 8 Keys Replacement: 步骤 2 中的图像 1,2 Midiman Oxygen 8 Keys Replacement: 步骤 2 中的图像 2,2
      • Remove the two highlighted 10 mm M3 galvanized machine screws using the J1 head fro the iFixit Tool Kit or a comparable tool.
      询问修复机器人
      添加评论
    3. Midiman Oxygen 8 Keys Replacement: 步骤 3 中的图像 1,3 Midiman Oxygen 8 Keys Replacement: 步骤 3 中的图像 2,3 Midiman Oxygen 8 Keys Replacement: 步骤 3 中的图像 3,3
      • Removal of Ribbon Cables
      • Prior to removal, note, mark, or take photo’s of the position of all connectors. Specifically note the side that the red wire is on, as ribbon cables are polarized cables that must be re-installed correctly. Installing the cables backwards may cause damage to the device or significantly hinder the troubleshooting process.
      • To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
      询问修复机器人
      添加评论
    4. Midiman Oxygen 8 Keys Replacement: 步骤 4 中的图像 1,2 Midiman Oxygen 8 Keys Replacement: 步骤 4 中的图像 2,2
      • Remove the key assembly from the key board.
      • What remains is the back plate and the top plate assemblies.
      询问修复机器人
      添加评论
    1. Midiman Oxygen 8 Keys Replacement, Keys: 步骤 5 中的图像 1,1
      在这个步骤中使用的工具:
      • The keys are retained via a tension spring. The removal of these springs is simple using the hooked needle point tweezers from the IFixit Toolkit.
      询问修复机器人
      添加评论
    2. Midiman Oxygen 8 Keys Replacement: 步骤 6 中的图像 1,2 Midiman Oxygen 8 Keys Replacement: 步骤 6 中的图像 2,2
      • To remove, simply insert one of the tweezer ends through the opening at the end of the spring.
      • Press the end between the spring windings after the windings start to reduce in size towards the inside of the spring.
      询问修复机器人
      添加评论
    3. Midiman Oxygen 8 Keys Replacement: 步骤 7 中的图像 1,1
      • Next, clasp the spring windings with the tweezers and gently apply tension outward.
      • The spring should thin slightly and be easily raised up and out of the retaining keyway.
      • This will free the key from the keyboard assembly for repair or replacement.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Scott Miller
于10/04/16注册
437 声望
创作了4篇指南
团队
USF Tampa, Team 1-6, Sullivan Fall 2016 USF Tampa, Team 1-6, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S1G6
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 32
总计 1,150
