跳转到主内容
加入维修社区 - 创建账户
Microtek ScanMaker 5900 New Ribbon Cable Replacement
你所需要的
    1. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove serial port connection: 步骤 1 中的图像 1,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove serial port connection: 步骤 1 中的图像 2,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove serial port connection: 步骤 1 中的图像 3,3
      • Loosen the screws on the serial port by turning them counter clockwise by hand.
      • After loosening the screws, pull the serial port out.
      询问修复机器人
      添加评论
    2. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove Lid: 步骤 2 中的图像 1,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove Lid: 步骤 2 中的图像 2,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove Lid: 步骤 2 中的图像 3,3
      • Lift lid to its vertical position.
      • Pull lid straight up to remove it from the scanner.
      询问修复机器人
      添加评论
    1. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Detach plastic latches: 步骤 3 中的图像 1,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Detach plastic latches: 步骤 3 中的图像 2,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Detach plastic latches: 步骤 3 中的图像 3,3
      • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
      询问修复机器人
      添加评论
    2. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Continue latch detachment: 步骤 4 中的图像 1,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Continue latch detachment: 步骤 4 中的图像 2,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Continue latch detachment: 步骤 4 中的图像 3,3
      • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
      • Go all the way along the chassis until you can lift the upper lid.
      询问修复机器人
      添加评论
    3. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Fully remove the upper lid: 步骤 5 中的图像 1,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Fully remove the upper lid: 步骤 5 中的图像 2,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Fully remove the upper lid: 步骤 5 中的图像 3,3
      • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
      • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
      • Grab the ribbon cable and gently pull it out of its slot with your fingers.
      • The upper lid can now safely be removed from the bottom lid.
      询问修复机器人
      添加评论
    1. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove outer plastic housing: 步骤 6 中的图像 1,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove outer plastic housing: 步骤 6 中的图像 2,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove outer plastic housing: 步骤 6 中的图像 3,3
      • Lift up the central plastic housing inside the scanner.
      • There are four plastic tabs located on the outer plastic housing. Push on each of these and pull to remove it.
      • Underneath you will see that the ribbon cable is attached to the circuit board.
      询问修复机器人
      添加评论
    2. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from circuit board: 步骤 7 中的图像 1,2 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from circuit board: 步骤 7 中的图像 2,2
      在这个步骤中使用的工具:
      • Grab onto ribbon cable with tweezers and gently pull until it come outs.
      询问修复机器人
      添加评论
    3. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from central plastic housing: 步骤 8 中的图像 1,2 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from central plastic housing: 步骤 8 中的图像 2,2
      • Simply remove the ribbon cable from within the holes it is wrapped through.
      询问修复机器人
      添加评论
    4. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove the ribbon cable from between the plastic prongs on the bottom of the scanner.: 步骤 9 中的图像 1,1
      • Grab the ribbon cable, and gently pull it off of the bottom of the scanner.
      询问修复机器人
      添加评论
    5. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from circuit board: 步骤 10 中的图像 1,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from circuit board: 步骤 10 中的图像 2,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from circuit board: 步骤 10 中的图像 3,3
      • Peel back the sticky metal from the other side of the ribbon cable.
      • Use tweezers to gently remove the ribbon cable from the circuit board.
      询问修复机器人
      添加评论
    6. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable: 步骤 11 中的图像 1,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable: 步骤 11 中的图像 2,3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable: 步骤 11 中的图像 3,3
      • Remove the metal housing for the ribbon cable at the base of the scanner.
      • Use the tweezers to slide off the metal housing.
      • The ribbon cable is now completely free to be replaced.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G9
2 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 24
总计 2,033
