跳转到主内容
加入维修社区 - 创建账户
Microtek ScanMaker 5900 New Locking Mechanism Replacement
你所需要的
  1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: 步骤 1 中的图像 1,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: 步骤 1 中的图像 2,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: 步骤 1 中的图像 3,3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
    询问修复机器人
    添加评论
  2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: 步骤 2 中的图像 1,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: 步骤 2 中的图像 2,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: 步骤 2 中的图像 3,3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
    询问修复机器人
    添加评论
  3. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: 步骤 3 中的图像 1,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: 步骤 3 中的图像 2,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: 步骤 3 中的图像 3,3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
    询问修复机器人
    添加评论
  4. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: 步骤 4 中的图像 1,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: 步骤 4 中的图像 2,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: 步骤 4 中的图像 3,3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
    询问修复机器人
    添加评论
  5. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: 步骤 5 中的图像 1,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: 步骤 5 中的图像 2,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: 步骤 5 中的图像 3,3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
    询问修复机器人
    添加评论
  6. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: 步骤 6 中的图像 1,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: 步骤 6 中的图像 2,3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: 步骤 6 中的图像 3,3
    • Locate the locking mechanism in the front left hand corner of the device.
    • Gently push on it until it becomes loose.
    • Rotate and jiggle it until it comes out the bottom of the scanner.
    • Find a replacement locking mechanism and insert it into the scanner.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G9
2 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 35
总计 1,741
