跳转到主内容
加入维修社区 - 创建账户
Microsoft Surface Pro Kickstand Replacement
你所需要的
  1. Microsoft Surface Pro Kickstand Replacement, Kickstand: 步骤 1 中的图像 1,1
    • Turn the tablet so the back is facing up.
    • Lift the kickstand to access the screws.
    • Remove the two T5 Torx screws:
    • One from the left hinge
    • One from the right hinge
    询问修复机器人
    添加评论
  2. Microsoft Surface Pro Kickstand Replacement: 步骤 2 中的图像 1,1
    • To remove the kickstand, gently pull up until the three tabs slide out of the slots on the back of the device.
    添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
Mark
于10/09/13注册
764 声望
撰写一个指南
团队
Cal Poly, Team 8-20, Regan Fall 2013 Cal Poly, Team 8-20, Regan Fall 2013 的会员
CPSU-REGAN-F13S8G20
4 名成员
创作了16篇指南
1指南评论
I had trouble getting the center tab to slide out of the slot. After looking at the other tabs, which came out easily, I noticed that the tabs are not composed of a single piece but are actually two sheets glued together (like two pieces of tape). Somehow the two pieces of tape composing the center tab had come apart, exposing their adhesive surfaces, and sticking to an inner surface. I managed to push them apart enough from the outside with a flathead screwdriver so that I could slide the center tab out. However, the other piece is stuck inside the device.
artlives13 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 117
总计 41,082
