简介
Follow this guide to replace or upgrade the SSD in your Microsoft Surface Laptop 7 (13.8‑inch).
Before starting this repair, read through Microsoft's guide on best practices for SSD removal.
你所需要的
Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
Use your tweezers to pry up and remove the foot.
Repeat the process to remove the remaining feet.
在这个步骤中使用的工具:FixMat$36.95
Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
Heat an iOpener and lay it on the SSD for one minute to heat the tape on its left edge.
Use a Torx Plus 5IP screwdriver to remove the 2.9 mm‑long screw securing the SSD.
Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
