跳转到主内容
Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement
你所需要的
  1. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 3,3
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Flip your laptop over: 步骤 2 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Flip your laptop over: 步骤 2 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Flip your laptop over: 步骤 2 中的图像 3,3
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the feet: 步骤 3 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the feet: 步骤 3 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the feet: 步骤 3 中的图像 3,3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the lower case screws: 步骤 4 中的图像 1,2 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the lower case screws: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Detach the lower case: 步骤 5 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Detach the lower case: 步骤 5 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Detach the lower case: 步骤 5 中的图像 3,3
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement: 步骤 6 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement: 步骤 6 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement: 步骤 6 中的图像 3,3
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the lower case: 步骤 7 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the lower case: 步骤 7 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the lower case: 步骤 7 中的图像 3,3
    • Lift the lower case and remove it.
  8. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Disconnect the battery: 步骤 8 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Disconnect the battery: 步骤 8 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Disconnect the battery: 步骤 8 中的图像 3,3
    • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
  9. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement: 步骤 9 中的图像 1,2 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement: 步骤 9 中的图像 2,2
    • Use tweezers or your fingers to remove the battery connector cover.
  10. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement: 步骤 10 中的图像 1,2 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement: 步骤 10 中的图像 2,2
    • Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It may take a few tries to align the connector—don't try to force it into place.
  11. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the audio jack cover: 步骤 11 中的图像 1,2 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the audio jack cover: 步骤 11 中的图像 2,2
    • Use a Torx Plus 3IP screwdriver to remove the two screws from the right edge of the audio jack cover:
    • One 3 mm‑long screw in the top right corner
    • One 4.7 mm‑long screw in the bottom right corner
    • Use a Torx Plus 6IP screwdriver to remove the remaining 6.3 mm‑long screw in the top left corner.
  12. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement: 步骤 12 中的图像 1,2 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement: 步骤 12 中的图像 2,2
    • Remove the audio jack cover.
  13. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Disconnect the audio jack: 步骤 13 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Disconnect the audio jack: 步骤 13 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Disconnect the audio jack: 步骤 13 中的图像 3,3
    • Use a spudger to lift the hinged locking flap on the audio jack ZIF connector.
    • Use tweezers to grip the audio jack cable's pull tab and slide the cable out of its socket.
  14. Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the audio jack: 步骤 14 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the audio jack: 步骤 14 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) Audio Jack Replacement, Remove the audio jack: 步骤 14 中的图像 3,3
    • Slide the audio jack out of its recess and remove it.
    • During reassembly, insert the audio jack into its recess and push the jack into its cutout on the frame. Make sure the port is fully in its cutout—the outer edge should be flush with the frame.
结论
Spencer Day
于09/14/22注册
94,530 声望
创作了662篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,413篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 111
