简介
Use this guide to remove or replace the touchpad in your Microsoft Surface Laptop 4 (15-inch).
If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
你所需要的
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
The back feet recesses are closest to the back edge of the laptop.
The front feet recesses are closest to the front edge of the laptop.
在这个步骤中使用的工具:Tesa 61395 Tape$5.99
The rear feet have a single center clip.
The front feet have three clips and can only be reinserted one way.
If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
在这个步骤中使用的工具:FixMat$36.95
Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
Grip the top edge of the upper case above the keyboard and lift straight up to release it.
Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
Remove the upper case and set it keyboard-side down on a clean surface.
Use a T3 Torx driver to remove the eight 1.9 mm screws securing the touchpad cover.
Use the pointed end of a spudger to lift the locking flaps on the three ZIF connectors on the touchpad.
Use a T5 Torx driver to remove the six 3.1 mm screws securing the touchpad.
Push the touchpad up through the case and slide it towards the keyboard, freeing it from its front tab.
Remove the touchpad.
When lowering the touchpad into place, make sure all ribbon cables are out of the way.
Make sure the touchpad is under its front tab and the other two securing tabs are in place.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
另外一个人完成了本指南。
