跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Microsoft Surface Book Screen Replacement
你所需要的
  1. Microsoft Surface Book Screen Replacement, Screen: 步骤 1 中的图像 1,3 Microsoft Surface Book Screen Replacement, Screen: 步骤 1 中的图像 2,3 Microsoft Surface Book Screen Replacement, Screen: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    iSclack
    $24.99
    购买
    • Turn off your Surface Book and detach the display.
    • Heat and apply an iOpener or use a hair dryer or heat gun to heat the perimeter of the display, in order to soften the glue securing it.
    • Use a suction cup or iSclack or pull up on the edge of the display, and create a slight gap between the display glass and the frame.
    • Insert an opening pick into the gap.
    • Use only gentle force with the pick, and keep the display very hot (slightly too hot to touch). If you use too much force and/or allow the glue to harden, the glass will crack.
  2. Microsoft Surface Book Screen Replacement: 步骤 2 中的图像 1,2 Microsoft Surface Book Screen Replacement: 步骤 2 中的图像 2,2
    • Use the pick to slice all the way around the perimeter of the display to separate the glue.
    • Gently raise the display, but don't try to fully detach it until the cables underneath are disconnected.
  3. Microsoft Surface Book Screen Replacement: 步骤 3 中的图像 1,3 Microsoft Surface Book Screen Replacement: 步骤 3 中的图像 2,3 Microsoft Surface Book Screen Replacement: 步骤 3 中的图像 3,3
    • The ribbons are circled. Begin by removing the ribbon on the right (in red). With the curved tweezers, carefully remove the metal bracket to expose the end of the ribbon. Remove ribbon.
  4. Microsoft Surface Book Screen Replacement: 步骤 4 中的图像 1,3 Microsoft Surface Book Screen Replacement: 步骤 4 中的图像 2,3 Microsoft Surface Book Screen Replacement: 步骤 4 中的图像 3,3
    • Next, remove the metal shield covering the other ribbon. Then remove the ribbon.
结论
25等其他人完成本指南。
Wesley Kendrick
于02/15/17注册
2,103 声望
创作了2篇指南
团队
USF Tampa, Team 1-6, Sullivan Spring 2017 USF Tampa, Team 1-6, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S1G6
3 名成员
创作了14篇指南
30条评论
It is very unlikely you will get this screen off without breaking it. Luckily, my customer only wanted the SSD out of the device so he didn't care if I damaged it. This screen is crazy fragile and the glue is very very strong. Do not do this job thinking you will likely not break the screen, unless you have done it before.
Kevin Yaniak - 回复
The only way to remove it without breaking it is to use good scotch tape and completely cover the screen with a minimum 4 layers of tape. This will keep the screen intact - but you still have to be very careful.
Michael Griffiths - 回复
That’s definitely not the only way. I just did it with a guitar pick and heat pad. After doing a ton of Surface Pro 3’s, I think this one is actually pretty easy in comparison.
austin -
I needed 3 hours for this, Did this the first time. There is everything glued. and real hard to not break the screen.
Dennis Reimer - 回复
Can you put the screen back on after removing it?
Alex Shinnerl - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 107
过去 30 天: 476
总计 50,516
